[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#2150 (master - 6f1ff0c)
Build #2150 is still failing.
44 seconds
Yann Chemin
6f1ff0c Changeset →
modifying to support i.ortho.transform requirements
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@71063 15284696-431f-4ddb-bdfa-cd5b030d7da7
System message:
We have updated our sudo-enabled Precise images! Read our blog post for more details. Thank you! :rocket: :sparkles:
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
Need help? Mail support!
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
Hi guys,
Travis needs some love: Unable to locate External PROJ.4 includes in the configure process
checking for proj_api.h... no
configure: error: *** Unable to locate External PROJ.4 includes.
include/Make/Vars.make:1: include/Make/Platform.make: No such file or directory
make: *** No rule to make target `include/Make/Platform.make'. Stop.
On 08/05/2017 19:32, Travis CI wrote:
Build Update for GRASS-GIS/grass-ci
Build: #2150
Status: Still Failing
Duration: 44 seconds
Commit: 6f1ff0c (master)
Author: Yann Chemin
Message: modifying to support i.ortho.transform requirements
View the changeset: https://github.com/GRASS-GIS/grass-ci/compare/396bee849988...6f1ff0cc3d80
View the full build log and details: https://travis-ci.org/GRASS-GIS/grass-ci/builds/230047027?utm_source=email&utm_medium=notification
You can configure recipients for build notifications in your .travis.yml file. See https://docs.travis-ci.com/user/notifications
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Please follow the discussion started from the first failed commit for updates:
[GRASS-dev] Broken: GRASS-GIS/grass-ci#2145 (master - d37fa7c)
http://lists.osgeo.org/pipermail/grass-dev/2017-May/084921.html
http://lists.osgeo.org/pipermail/grass-dev/2017-May/084932.html
http://lists.osgeo.org/pipermail/grass-dev/2017-May/084933.html
checking for proj_api.h… no
make: *** No rule to make target `include/Make/Platform.make’. Stop.
