[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#289 (master - df4ce5c)
Build #289 is still failing.
9 minutes and 3 seconds
Markus Neteler
df4ce5c Changeset →
v.kernel: always show target raster resolution; fix dangling curly braces -Wdangling-else
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@66269 15284696-431f-4ddb-bdfa-cd5b030d7da7
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
For help please join our IRC channel irc.freenode.net#travis.
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis Pro could be your new best friend!
Travis CI is powered by
one has to check the *raw* log to find it:
https://travis-ci.org/GRASS-GIS/grass-ci/builds/81415377
--> Build Jobs
     --> 289.1
          --> scroll down!
               --> This log is too long to be displayed. Please reduce
the verbosity
                    of your build or download the *raw log*
==> https://s3.amazonaws.com/archive.travis-ci.org/jobs/81415379/log.txt
make[3]: Entering directory `/home/travis/build/GRASS-GIS/grass-ci/man'
GISBASE="/home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu"
ARCH="x86_64-pc-linux-gnu"
ARCH_DISTDIR="/home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu"
VERSION_NUMBER=7.1.svn VERSION_DATE=2015 python ./build_full_index.py
VERSION_NUMBER=7.1.svn VERSION_DATE=2015 python ./build_index.py
touch /home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/index.html
VERSION_NUMBER=7.1.svn VERSION_DATE=2015 python ./build_topics.py
touch /home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/full_index.html
VERSION_NUMBER=7.1.svn VERSION_DATE=2015 python ./build_keywords.py
touch /home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/topics.html
./build_graphical_index.py
touch /home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/graphical_index.html
./build_manual_gallery.py
touch /home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/keywords.html
./build_class_graphical.py
touch /home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/class_graphical.html
./parser_standard_options.py -t ../lib/gis/parser_standard_options.c
-f grass -o /home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/parser_standard_options.html
-p 'id="opts_table" class="scroolTable"'
  File "./parser_standard_options.py", line 157, in <module>
    args = parser.parse_args()
  File "/usr/lib/python2.7/argparse.py", line 1688, in parse_args
    args, argv = self.parse_known_args(args, namespace)
  File "/usr/lib/python2.7/argparse.py", line 1710, in parse_known_args
    default = self._get_value(action, default)
  File "/usr/lib/python2.7/argparse.py", line 2239, in _get_value
    raise ArgumentError(action, msg)
argparse.ArgumentError: argument -t/--text: can't open '': [Errno 2]
No such file or directory: ''
make[3]: *** [/home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/parser_standard_options.html]
Error 1
make[3]: *** Waiting for unfinished jobs....
make[3]: Leaving directory `/home/travis/build/GRASS-GIS/grass-ci/man'
make[2]: *** [default] Error 2
(anyone editing this may also fix the typo "scroolTable" --> "scrollTable")
2015-09-21 18:47 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
Error 1
right, this is a know issue [1]. Martin
[1] https://lists.osgeo.org/pipermail/grass-dev/2015-September/076392.html
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
