[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#301 (master - 91ef345)
Build #301 is still failing.
7 minutes and 5 seconds
Markus Neteler
91ef345 Changeset →
d.legend, d.vect.thematic: add keyword
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@66316 15284696-431f-4ddb-bdfa-cd5b030d7da7
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
For help please join our IRC channel irc.freenode.net#travis.
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis Pro could be your new best friend!
Travis CI is powered by
