[GRASS-dev] Still Failing: GRASS-GIS/grass-ci#653 (master - 7b5db2b)
Build #653 is still failing.
2 minutes and 38 seconds
Markus Metz
7b5db2b Changeset →
rasterlib, raster3dlib: use new compression fns
git-svn-id: https://svn.osgeo.org/grass/grass/trunk@67215 15284696-431f-4ddb-bdfa-cd5b030d7da7
System message:
Want to work for Travis CI? We’re growing our dev team. Come join us!
Want to know about upcoming build environment updates?
Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
Documentation about Travis CI
For help please join our IRC channel irc.freenode.net#travis.
Choose who receives these build notification emails in your configuration file.
Would you like to test your private code?
Travis CI for Private Projects could be your new best friend!
