[GRASS-dev] storing pointers in CELL_TYPE maps?
I'd like to store pointers in CELL_TYPE maps. These pointers contain the
adresses of the first element of linked lists (containing special
attributes for each cell of the raster map). This works out fine on my
machine, but I'm afraid this might not be the case on others. Is it safe
or just an ugly hack?
Volker
What do you mean by "store"? Storing pointers in files is usually
pointless, as they are normally only useful so long as the original
process persists.
If you're talking about storing them in memory in CELL arrays, that
won't normally work on 64-bit systems, where a CELL (i.e. "int") is 32
bits but pointers are 64 bits.
If the list nodes are of fixed size, it's likely to be better to have
a single array of nodes and uses indices to reference individual
nodes.
process persists.
yes, that's what I meant to say
that
ok, damn :wink:
nodes.
that's my problem: I don't know the size of the array at compile time,
so I have to dynamically allocate memory. My idea was to use the GRASS
API to do that, but it seems I have to do this on my own. Or do you know
of another way?
I'm quite new to GRASS programming, but having something like
pointer("CELL") arrays would offer a lot of possibilities!
Thanks a lot!
Volker
> nodes.
of another way?
For a variable-sized in-memory array, use G_realloc() to enlarge it as
needed, e.g.:
  #define SIZE_INCREMENT 50
  int num_nodes;
  int max_nodes;
  struct node *nodes;
  int new_node(void)
    int n = num_nodes++;
    if (num_nodes >= max_nodes)
      max_nodes += SIZE_INCREMENT;
      nodes = G_realloc(nodes, max_nodes * sizeof(struct node));
    return n;
Bear in mind that G_realloc() may move the base of the array, so if
you have any pointers to elements, e.g.:
  struct node *node = &nodes[node_id];
those pointers cease to be valid after reallocation. Essentially,
refer to nodes primarily using indices and keep the use of pointers to
a minimum. In particular, don't store pointers to nodes within nodes.
If you need to be able to free list nodes for re-use, keep a linked
list of free nodes and allocate from that before extending the arrary,
e.g.:
  struct node {
    int next;
    /* other fields */
  int max_nodes;
  struct node *nodes;
  int free_list;
  int new_node(void)
    int n, i;
    if (free_list > 0)
      /* remove & return first node from free list */
      n = free_list;
      free_list = nodes[n].next;
    else
      /* enlarge array */
      n = max_nodes;
      /* add unused nodes to free list */
      for (i = n + 1; i < max_nodes - 1; i++)
        nodes[i].next = i + 1;
      nodes[max_nodes - 1].next = 0;
      free_list = n + 1;
    return n;
  void free_node(int n)
    nodes[n].next = free_list;
    free_list = n;
This is likely to be significantly more efficient than allocating
individual list nodes with e.g. G_malloc(). Each malloc()ed block has
a header and possibly padding, and having a large number of individual
blocks can affect the time taken by malloc/free.
> > nodes.
> of another way?
needed, e.g.:
  int num_nodes;
  int max_nodes;
  struct node *nodes;
  int new_node(void)
    return n;
e.g.:
  struct node {
    int next;
    /* other fields */
  int max_nodes;
  struct node *nodes;
  int free_list;
  int new_node(void)
    int n, i;
    if (free_list > 0)
      n = free_list;
    else
      /* enlarge array */
      n = max_nodes;
      free_list = n + 1;
    return n;
    free_list = n;
Thanks a lot!!! I will give this a try,
Volker
