I am writing a raster module for image processing, and the
for(col=0;col<ncols;col++) loop behaves strangely (segfault), the
number of lines of code inside is 239 lines. If i reduce the number of
functions inside to a simple copy of an input raster, the number of
line being 15 less, then it does not seg fault.
The error is basically the variable col becoming a very large negative
number, which is constant for a compilation, may not be the same
actually in all modifications of the code tested.
The interesting thing is that it processes through 77 rows of Null
pixels (sending outrast[col] to G_set_d_null_value(..)) and when it
comes to the first real data processing, it gives the output value to
outrast[col], goes up the loop and at that moment, col passes from
1450 to -2085319823.
Anybody has any experience of similar event?
Any idea what could corrupt a for() loop variable?
I am also going to change gcc version in case it is a gcc bug.
Well, this was a gcc-4.3.1 20080321 version for Debian
I tried gcc-4.2.3 also for Debian and it crashed while giving the
processed pixel to outrast[col]...
Finally went to gcc-4.1.3 20080308 version for Debian (4.1.2-21) which
is working fine...
maybe of any use
Yann
On 01/04/2008, Yann Chemin <yann.chemin@gmail.com> wrote:
Hello,
This looks very much like a buffer overflow, i.e. you're writing
outside of the bounds of a array and overwriting "col".
Using a different compiler version may hide the bug. It's up to the
compiler how the function's stack frame is arranged, so if you use a
different compiler, you may end up overwriting a different variable,
possibly one which doesn't matter at the point that the corruption
occured.
While compilers do occasionally have bugs, its more likely that the
bug is in your code.
