____________________
C. Michael Barton
Arizona State University
Michael
C. Michael Barton
Well, maybe a fluke. I'll check again and report anything weird.
Michael
______________________________
C. Michael Barton
Tempe, AZ 85287-2402
USA
Should this be documented on wiki for grass7 new features,
so that there is one place people where can go to when updating
their scripts, workflows, edu material etc. to grass7? http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures
There is a change for r.mapcalc noted like this:
r.mapcalc: use pthreads for parsing
but it is not clear from this that every r.mapcalc expression that people have
will need to be modified to run in grass7
(if I understand the changes correctly - I haven't tried it enough yet).
Or we could just say - read the manual page for everything
when updating to grass7, it may be easier than trying to track all the changes
Helena
On Jul 17, 2011, at 12:47 PM, Markus Neteler wrote:
On Mon, Jul 11, 2011 at 7:36 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
This is from GRASS 7 compiled from svn trunk yesterday.
I'm simply trying to assign null values in an SRTM using r.mapcalc. I do the following statement...
I just ran this again and it works fine, with and without the spaces--and even copying over the original file. That is, it all works as originally expected it to work. I don't know why this did not work the other day. I tried it several times. The command I sent to the list was copied from my terminal produced all nulls. Now it produces the expected values.
Weird
Michael
C. Michael Barton
Michael:
in general it's a bad idea to read and write to the same map in a single step from any module.
doing this task with r.null may be easier.
I'm not sure if you complied with pthreads, but if so that may change
read/write behavior vs. grass6 ?
Helena:
that r.mapcalc is now a normal module using G_parser() and so requires
special care with '=' (as described by Markus) should definitely be
mentioned in any changes from grass6 list. fwiw over the last year I've
slowly been going around updating all grass6 scripts and help examples
I've come across to add the spaces to make them forward compatible.
pthreads doesn't parse, it breaks up the processing into multiple threads
internally for a performance gain.
(note the white spaces around "=", which is required in GRASS7 - a bit
unfortunate...)
It shouldn't be required if you explictly specify the "expression=".
It should only be required if "expression=" is omitted, to ensure that
the parser treats it as a "default option" argument and not an
option=value argument.
