[GRASS-dev] strange r.stats output -- bug?
Can anyone explain the behavior of r.stats when applied to a raster that has been aggregated using r.resamp.stats with the "mode" option? It seems to me that the output should look like the example below from r.stats on the original resolution map (250 meter resolution) in the fist example. However, this is not the case. When applied to the aggregated map (1000 meter resolution), r.stats reports binned cell values and counts.
GRASS 6.4.1 (northcentralus_albersequalarea):~ > r.resamp.stats -w input=mnwimifnfftgk7wt175v3_250m output=mnwimifnfftgk7wt175v3_1000m method=mode --verbose 100%
This all appears to work properly. If I export the raster to MATLAB and simply view the cell values they are all whole number like 500, 600, 700, etc....
However, when I run r.stats on each map, I get:
GRASS 6.4.1 (northcentralus_albersequalarea):~ > r.stats -cl input=mnwimifnfftgk7wt175v3_250m 100%
0 893025
100 18419
120 34024
170 125
260 18
380 527
400 4269
500 36610
600 163
700 12479
800 51090
900 53455
990 5
999 527
* no data 874
GRASS 6.4.1 (northcentralus_albersequalarea):~ > r.stats -cl input=mnwimifnfftgk7wt175v3_1000m
100%
0-3.917647 from to 929109
97.941176-101.858824 from to 11467
117.529412-121.447059 from to 32643
168.458824-172.376471 from to 1
258.564706-262.482353 from to 1
376.094118-380.011765 from to 30
399.6-403.517647 from to 383
497.541176-501.458824 from to 24231
599.4-603.317647 from to 12
697.341176-701.258824 from to 2184
799.2-803.117647 from to 50355
897.141176-901.058824 from to 55190
995.082353-999 from to 4
The output to r.stats from the 250 meter resolution map look fine... but doesn't make sense to me that the 1000 meter resolution map would have it's count and cell values binned into groups like 0-3.9, and 97.9-101.9, when I was using the "method=mode" flag in r.resamp.stats???
What am I missing here?
Thanks in advance
