[GRASS-dev] strange thing on compilation of cvs
I am moving to a Debian based distro (Kanotix: Debian unstable/sid).
did a fresh cvs update, in configure, i did not enable MySQL.
while installing, many (all?) vector modules failed, including
/lib/proj, the first one to fail on the list. While doing "make" in
/lib/proj, i discovered that it was requiring libmysqlclient... after
an apt-get install libmysqlclient15-dev, it is fixed.
is it a new requirement? or something i did wrong?
Yann
lib/proj uses GDAL, so it requires whatever GDAL requires. If GDAL
requires MySQL, then so does anything which uses GDAL.
If GDAL requires the MySQL client library, but you managed to install
the GDAL -dev package without installing the MySQL client -dev
package, that suggests that the GDAL -dev package doesn't have correct
dependency information.
The problem could lie elsewhere, but I'm fairly sure that it lies
outside of GRASS. If you don't use --with-mysql, there won't be any
references to libmysqlclient in any of the Makefiles, so the only way
it can be referenced is as a dependency of an external library.
And that library is probably GDAL, due to the number of optional
dependencies (one of which is MySQL).
Now we have a third report of the same problem with 6.3-cvs.
Solution: install the libgeos-dev package to get usr/lib/libgeos.so.
My guess is that recent grass63/lib/proj/ changes now call a new libproj
or gdal fn which uses GEOS calls.. No idea what change in GRASS63 it was,
just that it happened in the first two weeks of november. (my gdal
install hasn't been changed in many months and worked for many grass
compiles in that time)
I think the real bug is that Debian's libgdal-dev needs to depend on the
libgeos-dev package.
sarge$ apt-cache show libgdal1-1.3.1-dev
Version: 1.3.1-0.dgis.stable.2
Depends: libgdal1-1.3.1 (= 1.3.1-0.dgis.stable.2), libc6-dev, libcfitsio-dev, netcdfg-dev, libtiff4-dev, libjasper-1.701-dev, libpng12-dev, libjpeg62-dev, libungif4-dev, libhdf4g-dev, libpq-dev | postgresql-dev, libxerces26-dev, unixodbc-dev, libsqlite0-dev
Hamish
sorry, not libgeos; I replied without reading carefully enough. does
your gdal-config say anything about needing mysql?
$ gdal-config --dep-libs
-L/usr/lib -lgeos -lodbc -L/usr/lib -lxerces-c -lpthread -ljasper -lmfhdf -ldf -lgif -ljpeg -ltiff -lpng -lnetcdf -lcfitsio -L/usr/lib -lpq -lz -lpthread -lm -lrt -ldl
what version libgdal package does Kanotix use?
Hamish
PROJ doesn't use GEOS, but GDAL does.
If GDAL is a shared library, then anything which uses GDAL needs all
of its dependencies, regardless of exactly *which* GDAL functions it
calls.
Furthermore, even if GDAL is a static library,
"gdal-config --dep-libs" gives you all of the dependencies, not just
the ones which are needed for the specific object files which are
being used.
Trying to determine the dependencies for individual functions isn't
feasible, IMHO. Even if it was, I'm not sure that it would make much
difference for GDAL, as the "top-level" functions (e.g. GDALOpen())
will eventually reference most of the dependencies.
The fact that they only get used for specific data formats doesn't
affect anything; if GDAL was built with e.g. JPEG2000 support, you
will need the JPEG2000 library at link time, regardless of whether or
not you subsequently read any JPEG2000 files.
And presumably the -dev package for MySQL (or at least the client
library) as well.
The only issue specifically related to GRASS is that configure.in
doesn't actually perform a link test for GDAL. It just runs
gdal-config and sets the appropriate variables. If GDAL isn't usable,
you won't actually find out until you run "make".
We should probably add something like:
  ac_save_libs="$LIBS"
  LIBS="$GDAL_LIBS $LIBS"
  AC_CHECK_FUNC(GDALOpen,[AC_MSG_ERROR([*** Unable to use GDAL library.])])
  LIBS=$ac_save_libs
to the GDAL section of configure.in.
