Recently I did some tests (with Pietro Z) using "i.segment" on an RGB
orthophoto sample. If am not wrong, the module works with "groups" only.
Driven by the discussion
"ticket #1984: i.pca should accept also group names as input (like
r.out.gdal)"
I wonder whether the module will support subgroups at some point as well.
Thank you, Nikos
On Fri, May 31, 2013 at 10:06 PM, Nikos Alexandris
Correct.
r.out.gdal)"
Could be, if someone finds the time to implement it...
Markus M
