[GRASS-dev] submitting bugs
should new bug reports[1] be submitted to the existing tracker, or wait until
the osgeo move is done?
1. saving the results from a monitor, after setting the font to a TTF, does
not result in the TTF being respected when d.rast is used- however does work
when d.his is used...
cheers,
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
until the osgeo move is done?
Me, I'd say file it, but I'm not the one doing the work :wink:
d.rast (without -o) erases the screen history when it runs, as it runs full
screen. d.his doesn't. run d.font after d.rast, or d.rast -o.
d.font remembers the font being used as long as the monitor is open, so it will
appear like it is still on the list even though it has been cleared from the
command list. Running d.out.file etc using the current list in another monitor
will not know about the previously set font.
Hamish
      ____________________________________________________________________________________
Be a better sports nut! Let your teams follow you
with Yahoo Mobile. Try it now. http://mobile.yahoo.com/sports;_ylt=At9_qDKvtAbMuh1G1SQtBI7ntAcJ
That should probably be filed as a bug in d.rast.
Don't hesitate to use existing tracker until announced not
to. I'm going to migrate the bug database into Trac at OSGEO
when we move there for good.
Maciek
From MAILER-DAEMON Fri Nov 16 09:51:23 2007
Return-Path: <>
X-Original-To: grass-dev@lists.osgeo.org
Delivered-To: grass-dev@lists.osgeo.org
Received: from grass.itc.it (grass.fbk.eu [217.77.80.24])
  by lists.osgeo.org (Postfix) with ESMTP id B352CE00B29
  for <grass-dev@lists.osgeo.org>; Fri, 16 Nov 2007 09:51:22 -0500 (EST)
Received: from pyrosoma.intevation.org (wald.intevation.org [78.47.251.62])
  by grass.itc.it (8.13.1/8.13.1) with ESMTP id lAGEpLvV013065
  for <grass-dev@grass.itc.it>; Fri, 16 Nov 2007 15:51:21 +0100
Received: by pyrosoma.intevation.org (Postfix)
  id 51E6A40437; Fri, 16 Nov 2007 15:51:20 +0100 (CET)
Date: Fri, 16 Nov 2007 15:51:20 +0100 (CET)
From: MAILER-DAEMON@wald.intevation.org (Mail Delivery System)
To: grass-dev@grass.itc.it
MIME-Version: 1.0
Content-Type: multipart/report; report-type=delivery-status;
  boundary="297E240436.1195224680/pyrosoma.intevation.org"
Message-Id: <20071116145120.51E6A40437@pyrosoma.intevation.org>
Cc:
Subject: [GRASS-dev] Undelivered Mail Returned to Sender
X-BeenThere: grass-dev@lists.osgeo.org
X-Mailman-Version: 2.1.5
Precedence: list
List-Id: GRASS GIS Development mailing list <grass-dev.lists.osgeo.org>
List-Unsubscribe: <http://lists.osgeo.org/mailman/listinfo/grass-dev&gt;,
  <mailto:grass-dev-request@lists.osgeo.org?subject=unsubscribe>
List-Archive: <http://lists.osgeo.org/pipermail/grass-dev&gt;
List-Post: <mailto:grass-dev@lists.osgeo.org>
List-Help: <mailto:grass-dev-request@lists.osgeo.org?subject=help>
List-Subscribe: <http://lists.osgeo.org/mailman/listinfo/grass-dev&gt;,
  <mailto:grass-dev-request@lists.osgeo.org?subject=subscribe>
X-List-Received-Date: Fri, 16 Nov 2007 14:51:23 -0000
Status: O
Content-Length: 2403
Lines: 72
This is a MIME-encapsulated message.
--297E240436.1195224680/pyrosoma.intevation.org
Content-Description: Notification
Content-Type: text/plain
This is the Postfix program at host pyrosoma.intevation.org.
I'm sorry to have to inform you that your message could not be
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to <postmaster>
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
      The Postfix program
<noreply@wald.intevation.org>: unknown user: "noreply"
Content-Description: Delivery report
Content-Type: message/delivery-status
Reporting-MTA: dns; pyrosoma.intevation.org
X-Postfix-Queue-ID: 297E240436
X-Postfix-Sender: rfc822; grass-dev@grass.itc.it
Arrival-Date: Fri, 16 Nov 2007 15:50:58 +0100 (CET)
Final-Recipient: rfc822; noreply@wald.intevation.org
Action: failed
Status: 5.0.0
Diagnostic-Code: X-Postfix; unknown user: "noreply"
Content-Description: Undelivered Message
Content-Type: message/rfc822
Received: by pyrosoma.intevation.org (Postfix, from userid 33)
  id 297E240436; Fri, 16 Nov 2007 15:50:58 +0100 (CET)
Reply-To: grass-dev@grass.itc.it
To: noreply@wald.intevation.org
Subject: =?UTF-8?B?W2dyYXNzLWRvYyBJXVs1MjldIHYudm9yb25vaSBuZWVkcyBtZW50aW9uIG9mIHJlZ2lvbiBzZXR0aW5n?=
Content-type: text/plain; charset=UTF-8
Message-Id: <20071116145058.297E240436@pyrosoma.intevation.org>
doc I item #529, was opened at 2007-11-15 18:05
Status: Closed
Priority: 3
Submitted By: David Sampson (sampson)
Assigned to: Nobody (None)
Summary: v.voronoi needs mention of region setting
Issue status: fixed in CVS
Doc section: vector
GRASS version: 6.2.3
Doc timestamp (YYMMDD):
Comment By: Maciej Sieczka (msieczka)
Date: 2007-11-16 15:50
Message:
I must be blind - this manual fix has been already backported to GRASS 6.2 branch in CVS yesterday by Hamish. The online docs wil get update tomorrow propably (they are synchronized with CVS once a week).
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=207&aid=529&group_id=21
--297E240436.1195224680/pyrosoma.intevation.org--
I've removed this "feature" from d.rast. It no longer clears the
window.
