when updating SUBMITTING files we need to touch all the files in all
the branches. I would suggest to move this files to Trac wiki. What do
you think?
Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
you think?
Martin
On 10/06/14 10:41, Martin Landa wrote:
you think?
Sounds good to me. But I would leave a SUBMITTING file in the source code, even if it just contains a link to Trac.
Moritz
On Tue, Jun 10, 2014 at 9:01 AM, Moritz Lennert <
you think?Yes, see
http://trac.osgeo.org/grass/ticket/2103 Make SUBMITTING files more
accessible
Putting them to Trac seems the most easy think (comparing to creating HTML,
putting them to Doxygen, etc.).
There are also SUBMITTING* in addons. See:
http://trac.osgeo.org/grass/ticket/2104 Reorganize SUBMITTING files for
addons
This is a bit off what I though Trac wiki should be used but I actually
think that it fits pretty well (together with RFC documents), considering
what other OSGeo projects do and that you have the changes to the documents
appearing in Trac Timeline (while GRASS (media) wiki changes are just in
personal watch lists).
Just a link or something short like that is a good idea.
I see some RFC documents related changes in Trac wiki, are you moving also
`rfc` directory
http://trac.osgeo.org/grass/browser/grass/trunk/rfc
to Trac wiki? If yes, I agree. It goes with SUBMITTING*.
Vaclav
mlennert@club.worldonline.be> wrote:On 10/06/14 10:41, Martin Landa wrote:
you think?Yes, see
accessiblePutting them to Trac seems the most easy think (comparing to creating
HTML, putting them to Doxygen, etc.).There are also SUBMITTING* in addons. See:
addonsThis is a bit off what I though Trac wiki should be used but I actually
I discovered also this page (almost empty):
http://trac.osgeo.org/grass/wiki/BestPractise
There is for sure some overlap with SUBMITTING* files.
`rfc` directoryhttp://trac.osgeo.org/grass/browser/grass/trunk/rfc
OK, now I see the discussion on PSC:
[GRASS-PSC] releases schedule
http://lists.osgeo.org/pipermail/grass-psc/2014-June/001246.html
Vaclav
2014-06-10 15:26 GMT+02:00 Vaclav Petras <wenzeslaus@gmail.com>:
you think?Yes, see
accessiblePutting them to Trac seems the most easy think (comparing to creating HTML,
I started with SUBMITTING file [1]. Any review is welcome. The process
of transferring plain files to Trac wiki is quite time consuming, so I
will appreciate if anyone helps with other submitting files (just let
us know about that).
Thanks, Martin
On Wed, Jun 11, 2014 at 1:41 PM, Martin Landa <landa.martin@gmail.com>
wrote:
>>> you think?
> Yes, see
> accessible
HTML,
> putting them to Doxygen, etc.).I started with SUBMITTING file [1]. Any review is welcome. The process
us know about that).I'll now work on:
http://trac.osgeo.org/grass/wiki/Submitting/Python
http://trac.osgeo.org/grass/wiki/Submitting/wxGUI
I think that we should avoid duplication between C, Python and wxGUI. There
is a lot of general notes about SVN etc. One thing is maintenance but in
this case what more important is a developer reading through these files
and reading something about svn properties over and over again. So I would
vote for creation of
http://trac.osgeo.org/grass/wiki/Submitting/General
It can be also just in http://trac.osgeo.org/grass/wiki/Submitting/ but
.../General seems a little bit better for me.
Thanks Martin for starting this,
Vaclav
Thanks, Martin
On Wed, Jun 11, 2014 at 10:53 PM, Vaclav Petras <wenzeslaus@gmail.com>
wrote:Hi,
>>> you think?
> Yes, see
> accessible
HTML,
http://trac.osgeo.org/grass/wiki/Submitting/wxGUII think that we should avoid duplication between C, Python and wxGUI.
There is a lot of general notes about SVN etc. One thing is maintenance but
in this case what more important is a developer reading through these files
vote for creation ofhttp://trac.osgeo.org/grass/wiki/Submitting/General
I have few notes:
svn properties should be solved by svn propset script [1]. The submitting
files can then just contain instructions how to run it.
I think that the formatting should be more in the way of a standard page
with sections and subsections rather than the list. I did this for the
Python and wxGUI pages. It is of course harder to write because you have to
think what should be where and which sections to have but it is more
readable and we don't need the numbered paragraphs/rules.
[1]
http://trac.osgeo.org/grass/browser/grass-addons/tools/module_svn_propset.sh
VaclavThanks, Martin
2014-06-12 4:53 GMT+02:00 Vaclav Petras <wenzeslaus@gmail.com>:
I'll now work on:
Thanks!
this case what more important is a developer reading through these files and
reading something about svn properties over and over again. So I would vote
for creation of
Right, I started this page.
I have also added two missing pages:
http://trac.osgeo.org/grass/wiki/Submitting/Docs
http://trac.osgeo.org/grass/wiki/Submitting/TclTk
Review is highly welcome! Martin
2014-06-21 14:37 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
I removed all SUBMITTING files from active branches, I keep one
SUBMITTING file with link to trac. Martin
