[GRASS-dev] suggestion for g.region -a
Currently, if you use the -a flag with g.region it will align the region exactly to match the resolution of a map (e.g. g.region -a rast=myrast will set the region to exactly the resolution of myrast regardless of the extents) or the resolution specified in the res or ewres/nwres fields (e.g. g.region -a n=523 s=15 res=10 will adjust the extents a little to make sure the resolution is exactly 10).
However, -a is ignored if the map argument (rast=) or resolution arguments are blank. This means that if you want to change the extents and keep your current resolution, you need to specify the -a flag AND explicitly specify the resolution. Otherwise, the resolution will be adjusted slightly.
Could this be modified so that when the -a flag is used and resolution is NOT specified and a map is NOT specified (i.e., only changing extents) it aligns to the current resolution? That is, respect the -a flag when res/ewres/nsres= is blank and rast= is blank.
Michael
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
Actually, you need either vect= or res= (or nsres= or ewres=). rast=
doesn't have any effect. Also, the interpretation is different for
vect= compared to the resolution options.
It would be possible to implement the -a flag unconditionally,
although you would need to exclude the cases which already have a
defined meaning (e.g. "g.region -a nsres=..." only aligns the top and
bottom edges, leaving the left and right edges unchanged).
Yes. That sounds like a good idea.
Michael
____________________
Phone: 480-965-6262
Fax: 480-965-7671
