Hello,
init.sh is in trouble on svn,
sounds like the programs are not found
the directory indeed does not have those files.
Could anyone point to the place of generation of these files plz?
thanks
yann@siduxbox:~$ grass70
/usr/local/grass-7.0.svn/etc/Init.sh: 27: source: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 142: create_tmp: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 145: create_gisrc: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 148: read_gui: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 151: get_locale: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 155: set_paths: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 160: set_defaults: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 163: set_browser: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 183: grass_intro: not found
Starting GRASS ...
/usr/local/grass-7.0.svn/etc/Init.sh: 188: check_gui: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 199: set_data: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 202: read_gisrc: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 205: check_lock: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 208: make_fontcap: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 214: db.connect: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 218: check_shell: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 220: check_batch_job: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 222: start_gui: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 224: clear_screen: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 232: show_banner: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 232: say_hello: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 232: show_info: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 246: default_startup: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 250: clear_screen: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 252: clean_temp: not found
cp: cannot stat `': No such file or directory
/usr/local/grass-7.0.svn/etc/Init.sh: 259: cleanup_tmpdir: not found
/usr/local/grass-7.0.svn/etc/Init.sh: 263: done_message: not found
Yann
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
