[GRASS-dev] svn access
Radim wrote:
May I get svn write access? My
account on osgeo is 'rblazek'.
a post to the grass-psc list w.r.t. RFC2 is needed, as described here:
https://trac.osgeo.org/grass/wiki/HowToContribute#ProcedureforgainingGRASS-SVNwriteaccess
(we all had to do it; you are already listed in trunk/contributors.csv
as a committer for whatever that means)
otherwise, totally fine by me..
Hamish
OK, patch attached, fix for QGIS crash.
I know, I should create a new ticket and then make a comment with the
patch attached, right?
Well, if anybody cares, here it is.
Radim
Hamish
(attachments)
mapset_nme.c.patch (644 Bytes)
2009/5/14 Radim Blazek <radim.blazek@gmail.com>:
applied in r37234.
Martin
BTW I hope that Radim will get svn write access at the end :wink:
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
