[GRASS-dev] SVN error in Add-Ons
While doing a couple of updates this afternoon, suddenly svn refused updates,
saying this:
# svn ci -m "fix bug"
svn: Commit failed (details follow):
svn: Unrecognized URL scheme for
'https://svn.osgeo.org/grass/grass-addons/gipe/r.out.vic
Anybody could check the server please?
Yann
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
On Mon, Apr 14, 2008 at 12:39 PM, Yann Chemin <yann.chemin@gmail.com> wrote:
saying this:
svn ci -m “fix bug”
seems to work fine - I just submitted something.
just woke up,
yes still a problem. Same problem.
Yann
On 14/04/2008, Frank Warmerdam <warmerdam@pobox.com> wrote:
Yann Chemin wrote:
> Hi,
updates,
> saying this:
Yann,
Is this still a problem for you? Have you heard if it happens to others
too?
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | President OSGeo, http://osgeo.org
Yann Chemin
Yann Chemin wrote:
just woke up,
Yann,
I just tried a commit in this area and it seems to work fine. I suspect
your svn client does not support https (compiled without it), though I
can't think of any reason this would have recently changed.
I did:
warmerda@gdal64[26]% svn checkout https://svn.osgeo.org/grass/grass-addons/gipe/
r.out.vic
A r.out.vic/main.c
A r.out.vic/description.html
A r.out.vic/veg_lib.c
A r.out.vic/Makefile
Checked out revision 30991.
warmerda@gdal64[27]% ls
r.out.vic
warmerda@gdal64[28]% cd r.out.vic/
warmerda@gdal64[29]% ls
description.html main.c Makefile veg_lib.c
warmerda@gdal64[30]% svn status
warmerda@gdal64[31]% vi Makefile
warmerda@gdal64[32]% svn status
M Makefile
warmerda@gdal64[33]% svn commit -m "test commit" Makefile
Authentication realm: <https://svn.osgeo.org:443> GRASS Subversion Repository
Password for 'warmerda':
Username: warmerdam
Password for 'warmerdam':
Sending Makefile
Transmitting file data .
Committed revision 30992.
Forgive me for the rather pointless commit.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
refused updates, saying this:
FWIW, I saw a similar error message a few days ago but then it was
because I miss wrote the directory name, like
https://svn.osgeo.org/grass/trunk/
instead of correct:
https://svn.osgeo.org/grass/grass/trunk/
works for me:
$ svn co https://svn.osgeo.org/grass/grass-addons/gipe/r.out.vic \
if I put a typo in the addons dir structure I get the error:
  svn: URL '.../grass/grass-addon/...' doesn't exist
if I put a typo in the project name I the less helpful error:
  svn: PROPFIND request failed on '/gras/grass-addons/...'
  svn: PROPFIND of '/gras/grass-addons/...': 405 Method Not Allowed
(https://svn.osgeo.org)
maybe try the checkin with full path and filename from the grass-addons
"root" dir? try with a fresh checkout?
does "svn diff" work?
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
svn diff works fine.
??? (at a loss here)
  instead of correct:
works for me:
Hamish
Yann Chemin
I tried a fresh check out and it seems that it runs into the same problem...
# svn co https://svn.osgeo.org/grass/grass-addons/
svn: Unrecognized URL scheme for 'https://svn.osgeo.org/grass/grass-addons
I suppose that svn got allergic to https as you suggested, but I did
not see that subversion got upgraded recently in my box... Definitely
not while I was working.
Still not clear...
On 15/04/2008, Frank Warmerdam <warmerdam@pobox.com> wrote:
Yann Chemin wrote:
> Hi,
> just woke up,
Yann,
I did:
r.out.vic
A r.out.vic/main.c
r.out.vic
M Makefile
Repository
Repository
Username: warmerdam
Sending Makefile
Best regards,
warmerdam@pobox.com
Yann Chemin
Are you using it with URLs, though?
If you just use svn diff on a local file or directory, it just
compares the working copy with the local original copy, so network
access doesn't come into it.
Note that the svn libraries rely upon the Neon library for HTTP/WebDAV
access, which in turn relies upon OpenSSL for SSL.
It's possible that the problem could be caused by an update to either
of those libraries, or a configuration change for OpenSSL (Neon
doesn't appear to have any configuration).
OK,
that must be something in this line that happened,
I do not record all the time if such software gets upgraded.
I'll check that up after work today,
Thanks for the help !
Yann
Yann Chemin
