[GRASS-dev] SWIG-Python lacking from install sequence in main Makefile
still SWIG-Python is lacking from install sequence in main Makefile.
Is there a reason for that? Say, how to use the examples like
rasteraccess.py when I have "just" the installed GRASS version?
Installation shouldn't need any special treatment in the top-level
Makefile.
6.x still doesn't build the swig directory, but 7.0 does.
to remind from an earlier thread:
building relbr6.4 swig/python/ from Debian/Etch (swig version 1.3.29-2.1)
fails with:
utils_wrap.c: In function 'pyseq_to_ptr':
utils_wrap.c:2495: error: 'Py_ssize_t' undeclared (first use in this function)
utils_wrap.c:2495: error: (Each undeclared identifier is reported only once
utils_wrap.c:2495: error: for each function it appears in.)
utils_wrap.c:2495: error: expected ';' before 'len'
utils_wrap.c:2522: error: 'len' undeclared (first use in this function)
utils_wrap.c: In function 'pyobj_to_ptr':
utils_wrap.c:2570: error: 'Py_ssize_t' undeclared (first use in this function)
up until a couple of 6.4 RCs ago it built ok.
Hamish
On Sat, Jul 18, 2009 at 6:48 AM, Glynn Clements<glynn@gclements.plus.com> wrote:
Makefile.
Right.
Now GRASS 6.4 + 6.5 do, I have updated
Makefile
swig/Makefile
accordingly.
fails with:
See
http://n2.nabble.com/grass7-build-failing-for-swig-python-td3074306.html
and
http://www.mail-archive.com/bug-gnubg@gnu.org/msg03894.html
http://www.mail-archive.com/bug-gnubg@gnu.org/msg03895.html
So, specific to the version which you use.
Hamish:
> version 1.3.29-2.1) fails with:
Markus:
See
and
As it is a >= version issue and not a bug in a specific release,
some sort of #ifdef MAJOR_VERSION && MINOR_VERSION test around
a #include <Python.h> seems in order.
Hamish
Hamish:
Markus:
> See
> and
Hamish:
I am trying to find where to handle something like that,
- utils*.c is auto-generated by swig.
- Python.h is found by ./configure and stored in Platform.make:PYTHONINC
   and PYTHONCFLAGS
- Can something be added to the utils_wrap.c: Makefile rule ???
also from swig/python/README todo item: at build-time we should byte
compile the .pyc version of our python libs so that users do not have
to wait a long time the first time they run GRASS. If installed without
write permissions by normal users (typical case for packaged Linux
anyway) .pyc files will not be cached and startup will always take a
long time.
e.g. on WinGRASS the wxGUI takes /very/ long to start up, with no feedback
except for hard drive access LED that anything is happening for like 20
seconds (ok, slow classmate PC netbook, but..) I am not totally sure
this is the main cause of that delay, but I'd wager that it doesn't help.
Hamish
> Hamish:
   and PYTHONCFLAGS
hmmm. utils_wrap.c has:
/* Python.h has to appear first */
#include <Python.h>
and make correctly includes -I/usr/include/python2.4,
gcc -I/usr/local/src/grass/svn/releasebranch_6_4/dist.i686-pc-linux-gnu/include -ggdb -march=pentium4 -Wall -Werror-implicit-function-declaration -fPIC -DPACKAGE=\""grasslibs"\" -fPIC -I/usr/include/python2.4 -I/usr/include/python2.4 -DPACKAGE=\""grasslibs"\" -I/usr/local/src/grass/svn/releasebranch_6_4/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-gnu/utils_wrap.o -c utils_wrap.c
utils_wrap.c:2496: error: 'Py_ssize_t' undeclared (first use in this function)
utils_wrap.c:2496: error: (Each undeclared identifier is reported only once
utils_wrap.c:2496: error: for each function it appears in.)
but /usr/include/python2.4/ headers only mentions 'Py_ssize_t' in a
comment of pymem.h.
In python 2.5 include files it is defined in pyport.h.
so (IIUC) swig 1.3.29 requires python >= 2.5 ?
Hamish
Hamish:
I can get a little further if I iteratively add this patch to *_wrap.c:
--- grass_wrap.c.ORIG 2009-07-20 13:06:52.000000000 +1200
+++ grass_wrap.c 2009-07-20 13:07:15.000000000 +1200
@@ -111,6 +111,11 @@
#include <Python.h>
+/* needed for Python 2.4 */
+#ifndef Py_ssize_t
+typedef size_t Py_ssize_t;
+#endif
  * swigrun.swg
until I get to proj_wrap.c which then fails with:
In file included from proj_wrap.c:2660:
include/grass/gprojects.h:23:29: error: ogr_srs_api.h: No such file or directory
(ogr_srs_api.h is present in /usr/include/gdal/)
Hamish
FWIW, the wrappers generated by SWIG 1.3.36 have:
  /* Py_ssize_t for old Pythons */
  /* This code is as recommended by: */
  /* http://www.python.org/dev/peps/pep-0353/#conversion-guidelines */
  #if PY_VERSION_HEX < 0x02050000 && !defined(PY_SSIZE_T_MIN)
  typedef int Py_ssize_t;
  # define PY_SSIZE_T_MAX INT_MAX
  # define PY_SSIZE_T_MIN INT_MIN
  #endif
IOW, you should just need a newer version of SWIG.
Hamish:
Glynn:
aka ask users to upgrade their OS in order to install a user app. :-/
If this can not be worked around, anyone know what the minimum required
swig version is?
Then we can at least document --with-python in REQUIREMENTS.html
Would it be like swig >= 1.3.x OR python >= 2.5 ?
it passes all the --with-python checks, could ./configure be improved
to bail if actual requirements are not met?
checking whether to use Python... yes
checking for python-config... /usr/bin/python2.4-config
checking for Python.h... yes
checking for swig... /usr/bin/swig
thanks,
Hamish
