[GRASS-dev] swig/python setup.py removed?
Martin, just wondering why swig/python was changed to use the makefile only instead of setup.py? Now we're back to the same problem we had with the wx nviz & vdigit and OSX before I added the ifdef's in the makefiles (then the recent switch to setup.py) -- wrong linking flags are used.
ie:
Python modules on OSX don't link the Python library directly, but instead use "-bundle -undefined dynamic_lookup".
LD should not reuse the global GRASS SHARED_LD because it has the OSX *library* linking flags, which include -dynamiclib which conflicts with the needed -bundle flag.
I can patch Python.make to set PYMOD_LDFLAGS conditionally for darwin, like what I did in nviz/vdigit, and set PYMOD_LD to "$(CXX) -shared". But I'm not sure that PYMOD_LD is appropriate for all platforms (OK on Linux, -shared is ignored on OSX).
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know. Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either. Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
2009/5/25 William Kyngesburye <woklist@kyngchaos.com>:
they hasn't been used at all. To avoid mess I removed them. Feel free
to update them and put them back.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
OK.
Is swig even built in a default configuration? It's not in the list of SUBDIRS in the main makefile.
If I cd to swig/python and make, I eventually get an error in proj_wrap because the PROJ include dir is missing from the compile flags, then after adding PROJINC, later in vector_wrap the GEOS include dir (GEOSCFLAGS).
On May 25, 2009, at 2:55 PM, Martin Landa wrote:
Martin
grass-dev mailing list
grass-dev@lists.osgeo.org
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
