[GRASS-dev] swig
sorry for off-topic. kindly forgive me
I would like to make a python gui toolkit based on FOX C++ Gui toolkit. I had some basic knowledge in swig based on tutorials given in the swig.org homepage. But my knowledge is not enough to make swig files for a whole GUI toolkit.
So anyone please give me some links on making swig interface for python.
Is there any good books for the making of swig interface. Treat me as a newbie to swig.
Is there any users who develop swig interface for python based on GRASS C/C++ library?
All I need is good start on making swig interfaces
Any help will be greatly appreciated.
Thanks in advance.
Rashad
Rashad
Hello Mohammed,
maybe you can use the vtk-grass-bridge? The vtk-grass-bridge is a
VTK/C++ wrapper around grass gis to provide direct access to grass
library in C++, Python and Java. So many GRASS GIS library functions
are available using this interface in Python, currently the raster-,
vector-, voxel-, gis- and dbmi-libraries.
Have a look at:
http://code.google.com/p/vtk-grass-bridge/
Here are some unit tests which show how to handle raster, vector and
the dbmi interface using the vtk-grass-bridge:
This is a test for raster map read - write access:
http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Raster/Testing/Python/GRASSRasterMapReaderWriterTest.py
This is a test for vector read access:
http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Vector/Testing/Python/GRASSVectorMapTopoReader.py
This test shows how to use the dbmi interface:
http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/DBMI/Testing/Python/vtkGRASSDbmiInterfaceReaderTest.py
This test shows the command line interface functionality:
http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/Common/Testing/Python/GRASSModuleTest.py
Here the C++ code of a VTK class which reads grass vector maps as
vtkPolyData and adds vector table columns as cell data.
I hope this may help you a bit. But i must warn you, GRASS GIS library
and so the vtk-grass-bridge is not designed to implement persistent
applications like a GUI using the library functions directly.
Feel free to ask any questions about the vtk-grass-bridge.
Best regards
Soeren
2010/9/21 Mohammed Rashad <mohammedrashadkm@gmail.com>:
newbie to swig.
C/C++ library?
Thanks in advance.
Rashad
Rashad
grass-dev mailing list
grass-dev@lists.osgeo.org
swig.org homepage.
newbie to swig.
The lack of sufficient documentation for SWIG is one of the reasons
why we have abandoned the use of SWIG in GRASS.
The only thing which I can suggest is to look at the wxPython source
code, as that is basically SWIG/Python bindings for wxWidgets, which
is also a C++ GUI toolkit.
