Sorry for the delay!
Please find attached a patch against trunk which adds GUI entries for
r3.in.lidar
r3.flow
r3.gradient
t.rast3d.algebra
t.rast.algebra
t.rast.contour
t.rast.to.vect
t.vect.algebra
v.decimate
v.out.lidar
and removes
v.krige from menu.
This list of new modules in trunk is fetched from: https://trac.osgeo.org/grass/wiki/Release/7.2.0-News
Stefan
-----Original Message-----
From: Anna Petrášová [mailto:kratochanna@gmail.com]
Sent: 30. september 2016 00:12
To: Blumentrath, Stefan <Stefan.Blumentrath@nina.no>
Cc: GRASS developers list (grass-dev@lists.osgeo.org) <grass-dev@lists.osgeo.org>
Subject: Re: [GRASS-dev] t.connect and t.rast.what not in GUI
On Thu, Sep 29, 2016 at 5:47 PM, Blumentrath, Stefan <Stefan.Blumentrath@nina.no> wrote:
Thanks Anna,
I just checked the new modules for 7.2.0 listed here:
And found that actually none of them seem to have made it into the GUI...
v.krige on the other hand is still in the GUI though it has been removed from the code...
I can try to create a new patch for that if you like...
That would be great. I would omit g.gui.datacatalog, d.frame, d.legend.vect and maybe some others, I don't think we have to have all modules accessible from menu.
Thank you
Stefan
Sent: 29. september 2016 15:20
On Wed, Sep 28, 2016 at 8:48 AM, Blumentrath, Stefan <Stefan.Blumentrath@nina.no> wrote:
It seems that t.connect and t.rast.what have not been added to the
GUI (both in G73 and G72)!
Please find attached a patch where I tried to add them. Hope that is
the proper way.
I placed t.connect under temporal, but it might be better suited
under Database, don’t now...
I added it there and backported to 7.2. Thank you!
Anna
Stefan
grass-dev mailing list
(attachments)
modules_gui.diff (3.21 KB)
