[GRASS-dev] t.rast.out.xyz not exporting all cells in the computational region
Hello devs,
I’m using the add-on t.rast.out.xyz to export my raster time series to a csv file. Here’s my region definition:
GRASS 7.3.svn (latlong_wgs84):~ > g.region -p raster=A20133052013312.L3m_8D_CHL_chlor_a_4km_arg
projection: 3 (Latitude-Longitude)
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 38S
south: 55S
west: 70W
east: 55W
nsres: 0:02:30
ewres: 0:02:30
rows: 408
cols: 360
cells: 146880
By running t.rast.out.xyz I would expect to have a file with 146880 rows (number of cells) and columns = the number of maps registered in the raster time series plus x & y coordinates. The latter works, I get the expected number of columns. However, the number of rows is much lower than expected.
GRASS 7.3.svn (latlong_wgs84):~ > t.rast.out.xyz strds=cla_monthly_average | wc -l
100%
Space time raster dataset cla_monthly_average exported to -
12891 << – less than 10% of the region!! No mask applied.
I observe the same behaviour when I vary the region size and also, when I export to a text file. Is this the expected behaviour? Am I missing something?
Thanks a lot for any advice/help!
Vero
On 28 November 2016 at 14:53, Veronica Andreo <veroandreo@gmail.com> wrote:
Hello devs,
Hi Vero,
I'm using the add-on t.rast.out.xyz to export my raster time series to a csv
file. Here's my region definition:
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 38S
south: 55S
west: 70W
east: 55W
nsres: 0:02:30
ewres: 0:02:30
rows: 408
cols: 360
cells: 146880
wc -l
100%
12891 << -- less than 10% of the region!! No mask applied.
something?
Maybe yes... do you have null cells (read r.out.xyz manual :wink: )?
r.univar can help you to discover the null cells :wink:
Vero
ciao
Luca
www.lucadelu.org
Ciao Lu,
Yes, of course I have NULL cells… cuac!
So, IIUC, as t.rast.out.xyz is a wraper for r.out.xyz it won’t export cells with NULL values, and from what I learnt just by trial and error, if the time series happens to start with a NULL cell then one gets an empty output. Hence, it’s only useful for time series without gaps…
Would that be too complicated to add support to also export NULL cells with some symbol such as “*” as other modules use??? Is this worth an enhancement ticket?
Anyway, this should also be mentioned in t.rast.out.xyz manual. I will send a diff later today.
Thanks a lot for the clarification
Vero
2016-11-29 15:12 GMT+01:00 Luca Delucchi <lucadeluge@gmail.com>:
Hello devs,
Hi Vero,
zone: 0
datum: wgs84
ellipsoid: wgs84
north: 38S
south: 55S
west: 70W
east: 55W
nsres: 0:02:30
ewres: 0:02:30
rows: 408
cols: 360
cells: 146880
wc -l
100%
something?
Maybe yes… do you have null cells (read r.out.xyz manual :wink: )?
Vero
ciao
Luca
www.lucadelu.org
On 29 November 2016 at 15:28, Veronica Andreo <veroandreo@gmail.com> wrote:
Ciao Lu,
Ciao,
Yes, of course I have NULL cells... cuac!
So, IIUC, as t.rast.out.xyz is a wraper for r.out.xyz it won't export cells
Hence, it's only useful for time series without gaps...
yes, most of the temporal module are wrapper for existing modules
some symbol such as "*" as other modules use??? Is this worth an enhancement
ticket?
it seems no, r.out.xyz is a python script using r.stats, r.out.xyz
force to return only no NULL values, but this is a flag in r.stats.
I propose to add a flag to r.out.xyz to permit to export also null
values, what do other devs think?
a diff later today.
wait, maybe we can fix it
Vero
ciao
Luca
www.lucadelu.org
Since it is a trivial change in r.out.xyz.py (conditionalize the r.stats' flag
  -n Do not report no data value
I would suggest to add a flag to optionally allow no data export (the
respective note in the manual page to be modified then).
The question is which flag letter to take here (keeing this in mind:
https://trac.osgeo.org/grass/wiki/MessageStandardization#Parametersandflags
Hello devs,
AFAIU, to activate the NULL export in r.out.xyz is then a trivial change, but we do not know which letter to use as flag because -n is already used to indicate the opposite behaviour (?). Is it too difficult to change default behaviour to export NULL values and keep then, the -n flag as in r.stats to not export/report NULL values?
I’m asking from ignorance, I would not know how to implement that myself.
Sorry for bothersome… and thanks much!!
Best,
Vero
2016-11-30 11:19 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
Since it is a trivial change in r.out.xyz.py (conditionalize the r.stats’ flag
On Wed, Nov 30, 2016 at 2:10 PM, Veronica Andreo <veroandreo@gmail.com> wrote:
Hello devs,
While this would make sense, it is a kind of API change for r.out.xyz.
The question is: where is it already used, and, would a "no data"
floodin in the output be an issue.
Honestly I was surprised to see that no data is excluded by default,
quite the opposite behaviour as we usually have.
best,
Hello devs,
yes it is, but we could release this change in 7.2
best,
ciao
Luca
www.lucadelu.org
Hi Vero,
Hello devs,
attached a trivial (untested) patch make make r.out.xyz behave as the rest.
Please check:
patch -p0 < r.out.xyz.diff
cheers
(attachments)
r.out.xyz.diff (793 Bytes)
Hello Markus
Thanks for the patch :slight_smile:
I applied it in my grass trunk and just tested for a map (146880 cells) that contains no data (45757 cells). I get all the pixels with data (101123), but nothing for the pixels with no data. It seems to be the same as before, no? (It is indeed, the same. I tested with the same map in grass72 with no patch)… and if I set the flag -n, I get:
ERROR: r.out.xyz: Sorry, is not a valid flag
Was that the expected result? or maybe i’m not using it properly… IIUC, I would expect to get the nulls by default and do not get them if I set the -n flag, is that right?
t.rast.out.xyz for the time series containing that map, gives an empty file… as before.
Best,
Vero
2016-12-05 23:08 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
Hi Vero,
Hello devs,
Please check:
cheers
On 06/12/16 10:53, Veronica Andreo wrote:
Hello Markus
in grass72 with no patch)... and if I set the flag -n, I get:
ERROR: r.out.xyz <http://r.out.xyz>: Sorry, <n> is not a valid flag
Was that the expected result? or maybe i'm not using it properly...
This sounds like the patch did not apply correctly. It contains the definition of the -n flag, so you should at least see that when you run r.out.xyz --h.
Did you run make after applying the patch ?
Moritz
I’m so sorry for the noise!! I forgot to run make :stuck_out_tongue: Anyway, I just did and tested again… works as expected!!! Cool!! :))
Thank you, Markus, for the patch and Moritz for the follow up!!
Vero
2016-12-06 12:31 GMT+01:00 Moritz Lennert <mlennert@club.worldonline.be>:
Hello Markus
ERROR: r.out.xyz <http://r.out.xyz>: Sorry, is not a valid flag
Moritz
On Tue, Dec 6, 2016 at 12:38 PM, Veronica Andreo <veroandreo@gmail.com> wrote:
I'm so sorry for the noise!! I forgot to run make :stuck_out_tongue: Anyway, I just did and
tested again... works as expected!!! Cool!! :))
great, it was a quick one (once in a while).
BTW: the parser code I simply generated with
r.stats --script
#%flag
#% key: n
#% description: Do not report no data value
#% guisection: No data
#%end
and remove the guisection part since IMHO not needed for r.out.xyz.
Big question: add to 7.2.0 or not? I am in favor.
2016-12-06 17:45 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
+1 Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Le 6 décembre 2016 17:53:48 GMT+01:00, Martin Landa landa.martin@gmail.com a écrit :
2016-12-06 17:45 GMT+01:00 Markus Neteler neteler@osgeo.org:
+1 Ma
I understand the motivation, but IIUC it’s definitely an API change that could break existing scripts, which is against our normal policy.
Why not make the flag mean the contrary, i.e. include null values ? Then it wouldn’t break anything…
I’m pretty sure that most people exporting data via r.out.xyz would expect null values to be excluded…
Moritz
Martin Landa
grass-dev mailing list
grass-dev@lists.osgeo.org
On Tue, Dec 6, 2016 at 12:34 PM, Moritz Lennert <
mlennert@club.worldonline.be> wrote:
Le 6 décembre 2016 17:53:48 GMT+01:00, Martin Landa <
landa.martin@gmail.com> a écrit :
>Hi,
>+1 Ma
I understand the motivation, but IIUC it's definitely an API change that
it wouldn't break anything...
I'm pretty sure that most people exporting data via r.out.xyz would
expect null values to be excluded...
r.out.xyz export XY and their values. When there is no value, nothing is
exported. This is the correct counterpart for r.in.xyz where you get NULLs
for cells without any input XY(Z).
I agree with Moritz. Adding a flag to export NULLs looks like the best way.
It doesn't break API nor expectations. NULLs simply not being there seems
like a better default here.
I'm pretty sure that most people exporting data via r.out.xyz would expect
Ah I see, they kind of belong together.
Any wording suggestion for such a flag?
And the same flag would go into t.rast.out.xyz then?
ok
ok.
I have submitted a new -i flag to include no data values (r70017).
This can be used for t.rast.out.xyz and backported for 7.2.1.
2016-12-06 23:06 GMT+01:00 Markus Neteler <neteler@osgeo.org>:
recorded at [1]. Does it mean that we can go ahead and release 7.2.0? Ma
[1] https://trac.osgeo.org/grass/wiki/Grass7Planning#a7.2.1tobebackported
Martin Landa
2016-12-06 23:24 GMT+01:00 Martin Landa <landa.martin@gmail.com>:
IMHO, if we wait to backport this new flag in r.out.xyz until 7.2.1, then t.rast.out.xyz could only be modified after that and this might happen in ~3-4 months from now according to a previous email from Martin. What I mean is that the original problem that was regarding exporting time series containing NULL values with t.rast.out.xyz, is then not solved, but postponed some months. Otherwise, we would have an add-on (t.rast.out.xyz) with features that only works along with trunk and that is not desirable, right?
Sorry if I create more noise here, honestly, I am not aware of the drawbacks of backporting right away :frowning:
best,
Vero
Martin Landa
