[GRASS-dev] t.rast.what flags
Hi devs,
I'm working on t.rast.what and I discovered that flags are not used in
the calling r.what module.
The comment said they are disabled for test issues [0], I think it is
more important to have these flags working and some problems test
problem instead don't use at all the flags.
What do you think?
[0] https://trac.osgeo.org/grass/browser/grass/trunk/temporal/t.rast.what/t.rast.what.py#L188
ciao
Luca
www.lucadelu.org
Hi Luca,
for what or why do you need the additional flags for r.what?
Ciao
Sören
2017-05-16 15:04 GMT+02:00 Luca Delucchi <lucadeluge@gmail.com>:
Hi devs,
What do you think?
ciao
Luca
www.lucadelu.org
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
On 16 May 2017 at 17:18, Sören Gebbert <soerengebbert@googlemail.com> wrote:
Hi Luca,
Hi Sören,
I just added a new flag in r.what to return also the cat of feature
and I would add this capability also to t.rast.what because I'm doing
a new module using this feature...
Ciao
Sören
ciao
Luca
www.lucadelu.org
Feel free to modify t.rast.what. However, i found it too complicated
to add category/attribute output to r.what/t.rast.what so i
implemented t.rast.sample that does it more elegant and outputs
category and vector attributes:
https://bitbucket.org/huhabla/temporal-raster-sampling
Ciao
Sören
2017-05-16 17:38 GMT+02:00 Luca Delucchi <lucadeluge@gmail.com>:
Hi Luca,
Hi Sören,
Ciao
Sören
ciao
Luca
www.lucadelu.org
ok, instead I found t.rast.what with timerow layout really useful with my scope.
I will submit small changes on t.rast.what
Ciao
Sören
ciao
Luca
www.lucadelu.org
