[GRASS-dev] table with the parser standard options
Dear devs,
I was not able to find a table in the GRASS manual pages with a
summary of all the default options as define in
parser_standard_options.c (lib/gis/parser_standard_options.c).
Therefore I wrote a python command line tool to extract them from the
source and print/write to a file in CSV/HTML format.
Probably I should use regexp but I'm not good with them...
The command line tool is attached.
Some usage example are:
$ python2 options.py -t lib/gis/parser_standard_options.c -f csv -o
stadard_options.csv
The command line should be able also to download the source file
directly from a link but it works only partially.
I believe we should add the generated table somewhere in the manual docs.
Should I add this python script to grass_addons/tools?
What do you think?
Pietro
(attachments)
options.py (5.4 KB)
On 1 July 2015 at 06:42, Pietro <peter.zamb@gmail.com> wrote:
Dear devs,
stadard_options.csv
if we want add the table in the manual docs (I'm really support this
idea) you should add this tool in the main code tools directory [0]
What do you think?
+1
Pietro
[0] https://trac.osgeo.org/grass/browser/grass/trunk/tools
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
On 01/07/15 06:42, Pietro wrote:
Dear devs,
There is http://grass.osgeo.org/programming7/parser__standard__options_8c.html#a1a5da9db1229a9bbc59d16ae84540bb8
which is referenced from the g.parser man page.
But I agree that a table like your's might be more helpful and that it should be accessible amongst the man pages.
Great, thanks !
May I just suggest the following small modification to make the html more readable:
--- options_orig.py 2015-07-01 11:57:54.146435072 +0200
+++ options.py 2015-07-01 11:57:30.234718383 +0200
@@ -105,7 +105,7 @@
      def html(self, endline='\n', indent=' '):
          """Return a HTML table with the options"""
- html = ["<table>"]
+ html = ["<table border=1>"]
          # write headers
          html.append(indent + "<tr>")
          html.append(indent * 2 + "<td>{0}</td>".format('option'))
Wouldn't it be better in tools/ directly in the source code ?
Moritz
Dear Luca and Moritz,
On Wed, Jul 1, 2015 at 11:58 AM, Moritz Lennert
ok, added.
ok, committed in r65534.
Some examples:
$ python2 tools/parser_standard_options.py -t
parser_standard_options.csv
$ tail parser_standard_options.csv
G_OPT_STR3DS_INPUT;;Name of the input space time raster3d
dataset;;old,str3ds,str3ds;input;name;;;;YES;TYPE_STRING
G_OPT_STR3DS_INPUTS;;Name of the input space time raster3d
datasets;;old,str3ds,str3ds;inputs;name;;YES;;YES;TYPE_STRING
G_OPT_STR3DS_OUTPUT;;Name of the output space time raster3d
dataset;;new,str3ds,str3ds;output;name;;;;YES;TYPE_STRING
G_OPT_STDS_TYPE;strds;Type of the input space time
dataset;;;type;name;;;strds,stvds,str3ds;NO;TYPE_STRING
G_OPT_MAP_INPUT;;Name of the input map;;old,map,map;map;name;;;;YES;TYPE_STRING
G_OPT_MAP_INPUTS;;Name of the input
maps;;old,map,map;maps;name;;YES;;YES;TYPE_STRING
G_OPT_MAP_TYPE;raster;Type of the input
map;;;type;name;;;raster,vector,raster_3d;NO;TYPE_STRING
G_OPT_T_TYPE;absolute;The temporal type of the space time
dataset;;;temporaltype;name;;;absolute,relative;NO;TYPE_STRING
G_OPT_T_WHERE;;Example: start_time > '2001-01-01
12:30:00';;;where;sql_query;WHERE conditions of SQL statement without
'where' keyword used in the temporal GIS framework;;;NO;TYPE_STRING
G_OPT_T_SAMPLE;start;The method to be used for sampling the input
dataset;;;sampling;name;;YES;start,during,overlap,contain,equal,follows,precedes;NO;TYPE_STRING
lib/gis/parser_standard_options.c -f html -o
parser_standard_options.html
$ head parser_standard_options.html
<table border=1>
  <tr>
    <td>option</td>
    <td>answer</td>
    <td>description</td>
    <td>descriptions</td>
    <td>gisprompt</td>
    <td>key</td>
    <td>key_desc</td>
    <td>label</td>
parser_standard_options.csv -s Flg
description;key
G_FLG_V_TABLE;Do not create attribute table;'t'
G_FLG_V_TOPO;Do not build topology;'b'
Best regards
Pietro
Dear All,
ok, added.
Some examples:
<table border=1>
  <tr>
    <td>option</td>
    <td>answer</td>
    <td>gisprompt</td>
    <td>key</td>
    <td>key_desc</td>
    <td>label</td>
description;key
In r66263 I improved the tools of Pietro (specially I added a new
GRASS output), moved it in man directory and added it to Makefile.
It now return a batter table, you should see it at this link [0] after
next manual compilation. Until now this page is not linked in any
other manual's page, let me know where do you think should be
better...
Best regards
Pietro
Regards from Seoul
[0] https://grass.osgeo.org/grass71/manuals/parser_standard_options.html
ciao
Luca
www.lucadelu.org
Hi Luca,
2015-09-19 6:37 GMT+02:00 Luca Delucchi <lucadeluge@gmail.com>:
better...
thanks, unfortunately travis has problem with that
GISBASE="/home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu"
ARCH="x86_64-pc-linux-gnu"
ARCH_DISTDIR="/home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu"
VERSION_NUMBER=7.1.svn VERSION_DATE=2015 python
./parser_standard_options.py -t ../lib/gis/parser_standard_options.c
-f grass -o /home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/parser_standard_options.html
-p 'id="opts_table" class="scroolTable"'
  File "./parser_standard_options.py", line 157, in <module>
    args = parser.parse_args()
  File "/usr/lib/python2.7/argparse.py", line 1688, in parse_args
    args, argv = self.parse_known_args(args, namespace)
  File "/usr/lib/python2.7/argparse.py", line 1710, in parse_known_args
    default = self._get_value(action, default)
  File "/usr/lib/python2.7/argparse.py", line 2239, in _get_value
    raise ArgumentError(action, msg)
argparse.ArgumentError: argument -t/--text: can't open '': [Errno 2]
No such file or directory: ''
make[3]: *** [/home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu/docs/html/parser_standard_options.html]
Error 1
Locally it's compiled fine.
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Il 19/set/2015 10:42, “Martin Landa” <landa.martin@gmail.com> ha scritto:
Hi Luca,
Hi Martin,
GISBASE=“/home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu”
ARCH=“x86_64-pc-linux-gnu”
ARCH_DISTDIR=“/home/travis/build/GRASS-GIS/grass-ci/dist.x86_64-pc-linux-gnu”
./parser_standard_options.py -t …/lib/gis/parser_standard_options.c
-p ‘id=“opts_table” class=“scroolTable”’
File “./parser_standard_options.py”, line 157, in
File “/usr/lib/python2.7/argparse.py”, line 1688, in parse_args
File “/usr/lib/python2.7/argparse.py”, line 1710, in parse_known_args
File “/usr/lib/python2.7/argparse.py”, line 2239, in _get_value
argparse.ArgumentError: argument -t/–text: can’t open ‘’: [Errno 2]
No such file or directory: ‘’
Error 1
Locally it’s compiled fine.
Yes I saw it, I don’t know what’s wrong there, Ivan do you have any idea?
Anyone has the same problem?
Martin
Ciao
Luca
2015-09-19 10:51 GMT+02:00 Luca Delucchi <lucadeluge@gmail.com>:
I check locally compilation log and found:
GISBASE="/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu"
ARCH="x86_64-unknown-linux-gnu"
ARCH_DISTDIR="/opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu"
-f grass -o /opt/src/grass_trunk/dist.x86_64-unknown-linux-gnu/docs/html/parser_standard_options.html
So nothing special, my Python is
Python 2.7.10 (default, Sep 13 2015, 20:30:50)
[GCC 5.2.1 20150911] on linux2
Ma
Martin Landa
-f grass -o
it seems to be problem with relative path. Luca, could you change it
to absolute path?
Martin
Martin Landa
2015-09-19 11:11 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
probably I overlooked that, but are you planning to link this page
somewhere, eg. in g.parser manual page?
Thaks, Martin
Martin Landa
Dear All,
ok, added.
Some examples:
<table border=1>
   <tr>
     <td>option</td>
     <td>answer</td>
     <td>gisprompt</td>
     <td>key</td>
     <td>key_desc</td>
     <td>label</td>
description;key
better...
Great job, thanks !
It should certainly be linked to from the g.parser man page (in replacement of the link to the programmer's manual).
Maybe there could also be a direct link in the "Miscellaneous & Variables" section ?
Moritz
in r66271 I have submitted an attempt to fix the Travis issue.
On Mon, Sep 21, 2015 at 1:11 PM, Moritz Lennert
Great job, thanks !
section ?
Yes, would be nice.
On 19 September 2015 at 11:11, Martin Landa <landa.martin@gmail.com> wrote:
-f grass -o
to absolute path?
tried in r66299, I hope this is fixing the problem in travis ci. Let's see
Martin
ciao
Luca
www.lucadelu.org
On 21 September 2015 at 19:02, Markus Neteler <neteler@osgeo.org> wrote:
Great job, thanks !
section ?
Yes, would be nice.
ok, I will add in g.parser and in the "Miscellaneous & Variables" box
ciao
Luca
www.lucadelu.org
-f grass -o
to absolute path?
absolute path didn't work, I also tried to protect the values of the
options but it didn't work too.
The error seems the the option -t/--text is empty, could be a problem
of argparse version?
Is there any way to contact the Travis-CI guys for some support?
I have no other ideas how to fix this problem, specially because it
seems related only to Travis....
ciao
Luca
www.lucadelu.org
Suggestion: add an "echo ..." there to print the actual line into the
log in order to better understand the issue?
ok, this is the diff, it is correct?
Index: Makefile
--- Makefile (revision 66300)
+++ Makefile (working copy)
@@ -87,6 +87,8 @@
        VERSION_NUMBER=$(GRASS_VERSION_NUMBER)
VERSION_DATE=$(GRASS_VERSION_DATE) \
        $(PYTHON) ./parser_standard_options.py -t
"$(GRASS_HOME)/lib/gis/parser_standard_options.c" \
        -f "grass" -o "$(HTMLDIR)/parser_standard_options.html" -p
+ @echo "****DEBUG****" $(PYTHON) ./parser_standard_options.py
-t "$(GRASS_HOME)/lib/gis/parser_standard_options.c" \
+ -f "grass" -o "$(HTMLDIR)/parser_standard_options.html" -p
endef
$(HTMLDIR)/topics.html: $(ALL_HTML)
ciao
Luca
www.lucadelu.org
On Wed, Sep 23, 2015 at 10:22 AM, Luca Delucchi <lucadeluge@gmail.com> wrote:
Index: Makefile
@@ -87,6 +87,8 @@
endef
I don't think it is correct (the " are not right I think) but you need
to send it either as attachment or HTML courier font formatted text...
thanks
2015-09-24 11:56 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
travis issue seems to be fixed in r66323 (thanks to Ivan Mincik) [1]. Ma
[1] https://travis-ci.org/GRASS-GIS/grass-ci/builds/81968450
Martin Landa
On 24 September 2015 at 16:10, Martin Landa <landa.martin@gmail.com> wrote:
Yes, I saw it... is there also an explanation about the fix?
Thanks a lot
Martin Landa
ciao
Luca
www.lucadelu.org
