[GRASS-dev] Temporal framework: error when trying to register vector maps using register_map_object_list()
Hello all,
I'm trying to register a list of VectorDataset objects in a STVDS
using tgis.register.register_map_object_list().
The same function works fine when trying to register a list of
RasterDataset objects.
However, when using it with VectorDataset objects, I get the following error:
  File "/usr/lib/grass72/etc/python/grass/temporal/register.py", line
480, in register_map_object_list
    if map_layer.metadata.get_min() is None and \
AttributeError: 'VectorMetadata' object has no attribute 'get_min'
Do I do something wrong or should I fill up a Trac issue?
Thanks for your help,
Laurent
On Thu, Feb 16, 2017 at 9:28 PM, Laurent C. <lrntct@gmail.com> wrote:
Hello all,
I didn't investigate, but that looks like a bug to me, so yes, please
create a ticket.
Anna
Laurent
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Its a bug, i will try to fix it.
Best regards
Soeren
2017-02-17 3:48 GMT+01:00 Anna Petrášová <kratochanna@gmail.com>:
Hello all,
create a ticket.
Anna
Laurent
This bug is hopefully fixed in trunk, please test.
After testing this will be backported to grass 7.2.
Best regards
Soeren
2017-02-17 21:19 GMT+01:00 Sören Gebbert <soerengebbert@googlemail.com>:
Best regards
Soeren
Hello all,
create a ticket.
Anna
Laurent
