Hello,
I'm writing a module that generates raster maps and register them in
newly created strds.
The temporal type of the generated strds depends on the entry values
of the module.
I've seen in the documentation that
register_maps_in_space_time_dataset() can read the timestamp from the
GRASS raster, so my module is currently doing the following:
- writes maps
- assign timestamp, either absolute or relative with r.timestamp
- at the end, register all the generated maps from a list using
But I end up with the following error with relative time:
File "/home/lo/Programación/t_sim_flood/gis.py", line 286, in
register_maps_in_strds
strds_id, maps=map_lst_str, unit='seconds')
File "/usr/lib/grass71/etc/python/grass/temporal/register.py", line
289, in register_maps_in_space_time_dataset
statement += map.insert(dbif=dbif, execute=False)
File "/usr/lib/grass71/etc/python/grass/temporal/abstract_map_dataset.py",
line 273, in insert
self.write_timestamp_to_grass()
File "/usr/lib/grass71/etc/python/grass/temporal/space_time_datasets.py",
line 242, in write_timestamp_to_grass
self._convert_timestamp())
line 124, in _convert_timestamp
start = datetime_to_grass_datetime_string(start_time)
File "/usr/lib/grass71/etc/python/grass/temporal/datetime_math.py",
line 817, in datetime_to_grass_datetime_string
if dt.tzinfo is not None:
AttributeError: 'NoneType' object has no attribute 'tzinfo'
The grass timestamp are well written and are visible with r.info.
If I give a start=0 to register_maps_in_space_time_dataset(), all the
maps are registered in the strds without generating errors, but they
all starts and ends at 0:
+-------------------- Relative time -----------------------------------------+
| Start time:................. 0
| End time:................... 0
| Relative time unit:......... seconds
| Granularity:................ 0
| Temporal type of maps:...... point
+-------------------- Spatial extent ----------------------------------------+
And the raster timestamps are overwritten.
I haven't tried yet with absolute type.
How should I proceed? Is there a way to avoid generating a temporary
text file to feed register_maps_in_space_time_dataset()?
Laurent
Hi Laurent,
please do not use the legacy r.timestamp module to set the time stamp
for maps. The feature to use time stamps set by r.timestamp was only
implemented, to migrate from old grass locations with time stamped
maps to the temporal framework approach more easily. I am not sure if
this works well with relative time.
The easiest way is to generate a text file with name, start time and
end time. If you insist to avoid using text files, then generate a
list of RasterDataset[1] objects, set the time for these objects
(set_absolute_time() or set_relative_time()) and use
register_map_object_list() [2] to register them in a space time raster
dataset.
[1] https://grass.osgeo.org/grass70/manuals/libpython/temporal.html#temporal.space_time_datasets.RasterDataset
[2] https://grass.osgeo.org/grass70/manuals/libpython/temporal.html#temporal.register.register_map_object_list
Best regards
Soeren
2015-10-09 17:13 GMT+02:00 Laurent C. <lrntct@gmail.com>:
Hello,
of the module.
- writes maps
line 273, in insert
Laurent
grass-dev mailing list
grass-dev@lists.osgeo.org
Hi Sören,
Thank you for your answer. I've made some tests with the second option
and it seems to works well. It looks like I don't need to use
.update() or .insert() before registering the RasterDataset list in
the DB. Could you please confirm that it is unnecessary?
Laurent
2015-10-09 22:45 GMT+01:00 Sören Gebbert <soerengebbert@googlemail.com>:
Hi Laurent,
dataset.
Best regards
Soeren
Hello,
of the module.
- writes maps
line 273, in insert
Laurent
Hi Laurent,
2015-10-13 11:26 GMT+02:00 Laurent C. <lrntct@gmail.com>:
Hi Sören,
You don't need to perform any insert() or update() yourself, the
register function takes care of that.
You only need to set the name, mapset and timestamp for the
RasterDataset objects, put them into a list and pass them to the
register function.
Have a look at this code from the temporal aggregation:
https://trac.osgeo.org/grass/browser/grass/trunk/lib/python/temporal/aggregation.py#L287
Line 287 to 296
Best regards
Soeren
Laurent
Hi Laurent,
dataset.
Best regards
Soeren
Hello,
of the module.
- writes maps
line 273, in insert
Laurent
