Hello,
I have some raster maps that have infinite values:
r.univar map=out_v17.2dev_theta7_fr_0005@EA2DT8A
total null and non-null cells: 96400
total null cells: 1840
Of the non-null cells:
n: 94560
minimum: 0.000291453
maximum: inf
range: inf
mean: inf
mean of absolute values: inf
standard deviation: -nan
variance: -nan
variation coefficient: -nan %
sum: inf
When trying to register them in a STRDS, I get an SQL error:
File "/home/laurent/Program/itzi/itzi/gis.py", line 452, in
register_maps_in_stds
unit=t_unit[t_type])
File "/usr/lib/grass72/etc/python/grass/temporal/register.py", line
499, in register_map_object_list
file=filename, dbif=dbif)
325, in register_maps_in_space_time_dataset
dbif.execute_transaction(statement)
File "/usr/lib/grass72/etc/python/grass/temporal/core.py", line
1021, in execute_transaction
return self.connections[mapset].execute_transaction(statement)
1315, in execute_transaction
self.cursor.executescript(statement)
OperationalError: no such column: inf
I'm using GRASS 7.2.0
Is there a solution to that issue?
Laurent
It seems that sqlite does nor support "inf" as valid numerical value.
There is no fast fix available for this issue. Can you avoid computing
infinite values?
Best regards
Soeren
2017-03-04 0:25 GMT+01:00 Laurent C. <lrntct@gmail.com>:
Hello,
n: 94560
maximum: inf
range: inf
mean: inf
variance: -nan
sum: inf
Laurent
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
On Mar 5, 2017 9:07 AM, “Sören Gebbert” <soerengebbert@googlemail.com> wrote:
It seems that sqlite does nor support “inf” as valid numerical value.
infinite values?
A similar issue may be this
#2343: GRASS 7: “inf” values break insert statements in v.rast.stats
Best
