[GRASS-dev] temporal modules cannot open database
Hi devs,
I have problem to open the temporal database (with grass70svn and grass71)
t.list
ERROR: Unable to connect to sqlite3 database:
/grassdata/latlong/ecad100_climate/tgis/sqlite.db
Exception: "unable to open database file"
Please use t.connect to set a read- and writable temporal database backend
permissions on the file seems to be correct,
ls -lh /grassdata/latlong/ecad100_climate/tgis/
totale 49M
-rw-r--r-- 1 lucadelu gis 49M set 3 2014 sqlite.db
Were there any changes in the temporal code that doesn't recognize the
old database structure?
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
Hi Luca,
i did not change the database structure of the temporal framework recently.
The exception seems to be from the sqlite3 backend, hence it should
not be related to different temporal database formats.
Can you access the database with the sqlite3 command directly?
sqlite3 /grassdata/latlong/ecad100_climate/tgis/sqlite.db
Best regards
Soeren
2015-06-11 15:14 GMT+02:00 Luca Delucchi <lucadeluge@gmail.com>:
Hi devs,
t.list
totale 49M
ciao
Luca
www.lucadelu.org
grass-dev mailing list
grass-dev@lists.osgeo.org
On 11 June 2015 at 21:54, Sören Gebbert <soerengebbert@googlemail.com> wrote:
Hi Luca,
Hi Soeren,
yes, I can see the tables and they seems coming from a temporal dataset :slight_smile:
Best regards
Soeren
ciao
Luca
www.lucadelu.org
Hi Luca,
is it possible that the path to the location has changed or that the
location was renamed?
Best regards
Soeren
2015-06-12 8:07 GMT+02:00 Luca Delucchi <lucadeluge@gmail.com>:
Hi Luca,
Hi Soeren,
Best regards
Soeren
ciao
Luca
www.lucadelu.org
On 25 June 2015 at 00:05, Sören Gebbert <soerengebbert@googlemail.com> wrote:
Hi Luca,
Hio Soeren
mmm I don't think so, but I'm not sure.
The path to db it seems correct using t.connect -l, do you have any
trick to solve this problem?
Best regards
Soeren
ciao
Luca
www.lucadelu.org
Hi Luca,
i just committed a patch in SVN that can handle modified location path's.
Please make an update of grass7.1 and then call t.connect -d in the
specific location/mapset to reset the default connection, which is
mapset specific.
I hope the temporal framework will find the correct database again.
Best regards
Soeren
2015-06-25 11:30 GMT+02:00 Luca Delucchi <lucadeluge@gmail.com>:
Hi Luca,
Hio Soeren
Best regards
Soeren
ciao
Luca
www.lucadelu.org
On Thu, Jun 25, 2015 at 5:53 AM, Sören Gebbert <soerengebbert@googlemail.com
wrote:
Hi Luca,
Thanks Soeren, I think I actually hit the issue before.
mapset specific.
Best regards
Soeren
wrote:
>> Hi Luca,
> Hio Soeren
>> Best regards
>> Soeren
> ciao
> Luca
> www.lucadelu.org
On 25 June 2015 at 11:53, Sören Gebbert <soerengebbert@googlemail.com> wrote:
Hi Luca,
Hi Soeren,
mapset specific.
yes now it works!
Best regards
Soeren
Thanks a lot
ciao
Luca
www.lucadelu.org
