[GRASS-dev] Temporary 3D raster or delete 3D raster in C
in r3.in.lidar I want to use temporary 3D rasters. There might be ways to avoid the need for it, but 3D raster is just the easiest thing for me.
What I need is to delete the temporary raster after I finish the processing. Ideally I would call something like “close and remove” so that no more things are written, just deleted. However, I would be fine also with just writing it using Rast3d_close() and then removing it.
Do you have some suggestions how to solve this?
Vaclav
