There are 2 issues being discussed here. I'll guess I'll go with the flow, however, and comment on both
On Aug 11, 2008, at 12:26 PM, Paul Kelly wrote:
On Mon, 11 Aug 2008, Maciej Sieczka wrote:
Paul Kelly pisze:
I think though, that connecting multiple layers to different tables is the main application for layers? Are they much use for anything else? In which case, calling them tables makes things clearer. Perhaps even table would be enough - each vector map can be connected to multiple tables, each vector map can have multiple tables, each vector map can have multiple table links... is there a big difference in meaning between those different sentences? I feel removing the word "link" improves the clarity of the meaning without adding any additional ambiguity.
I don't agree with Paul. In GRASS vector terminology the term "table"
already has a very well defined meaning and it must not be used for
anything else.
(A "table" is an object in the database that stores the given "layer"'s
attributes, and the "table" and "layer"'s geometrical features are
linked using "key column" in which the "categories" are stored inside
the "table".)
Agree 100%. In fact, that was exactly my point. In the interests of clarity/simplicity, I was proposing to consider a table as "belonging" to a particular map, e.g. the table containing a key column (or key field) whose values correspond to the categories in layer 1 of vector map x could be considered as table 1 of vector map x. The fact that tables may belong to multiple vector maps, and indeed exist independently outside of GRASS, doesn't IMO impede on the clarity of this relationship between a vector map and multiple tables: the same table may belong to different vector maps and be associated with a different table number in each.
See below.
Regarding Moritz's remark I indeed missed the fact that the vector map
having 0 or more "layers" does not directly imply it has the same number
of data "tables". Given that, "table link" to replace "layer" as I
suggested is bad. If we are to change the term, we should do it right.
How do you like "category set" then, "catset" in short? Together with
with replacing term vector "map" with vector "layer" it would yield:
Each vector "feature" (line, point etc.) can have 0 or more "categories"
in a vector "layer". Each "category" belongs to only 1 "category set".
Each "category set" of a vector "layer" can be connected or not with a
single database "table". The "key column" in that "table" stores the
"categories" of "features" present in the given "category set".
Any good?
I think we are thinking the same
IIUC, a category set is quite meaningless unless the table containing more information on each category in the set is also known. My proposal is simply to leave the concept that a category set can be meaningful in the context of more than one linked table to advanced users, and associate the table directory with the vector map. This could lead to the situation where, e.g. table 0 of vector map x and table 1 of vector map y refer to the same table.
My question is still open though - are there any other practical applications for layers, other than enabling vector maps to be connecyed to multiple tables?
Issue 1:
In short, yes. For example, when you color a vector area map randomly, it does so by cat numbers. If a map has multiple "layers" (i.e., catsets) with different features grouped according to cat values in different ways, you will get a different map depend which "layer" you choose. You also can query and/or display directly on the cats in a "layer"; selecting all the features with cat=1 in layer=1 might well be a different result from selecting all features with cat=1 in layer=2.
Each "layer" is a 1-column "table" tightly coupled to the features in a vector data file. You can use the column (i.e., cat) values in each of these coupled tables (i.e., layers) as key fields to match with the key fields of a loosely coupled attribute table. That is to link two tables in a RDBMS, you need a key field in each of the tables being linked. Each GRASS "layer" holds the key field (i.e., "cat" or "category") in the vector object table. These must be matched by a key field in an attribute table (i.e., with integer values only).
In this sense, we could call a layer a "cat table". However, to just refer to them as tables is something of a misnomer given that most people will be thinking of the potentially larger attribute tables. "Catset" also captures this concisely.
Talking about layers (in their current meaning) - there is no convenient
tool to report the number of layers in a vector map. There is only
v.category opt=report. Could v.info be extended in this regard? Oh, and
the regular v.info already reports number of "dblinks" (which I guess
might be renamed to "table links", but I won't insist), while v.info -t
doesn't. Could this be addressed too please?
With regard to calling maps something different though, I think that would be very confusing and not a good idea (especially if they were renamed to layers). Map has IMHO a much clearer meaning than layer. There is the issue of ambiguity with a printed map I suppose, but use of the word in that context is kind of non-technical I feel. The use of the word map has a clearly defined historical meaning in GRASS (and influences other words too, e.g. a mapset = a collection of maps - should this be renamed a layerset?) and I feel that it should stay.
Paul has points here. Yet I *guess* I'd prefer to trade legacy for
clarity anyway. Calling GRASS "maps" "layers" would improve clarity
IMHO, especially for newcommers. Word "map" has been in use for
centuries and the word immediately brings a nice picture with north
arrow, legend and stuff to my mind. "Layer" is *the* GIS word for a set
of features that can be represented graphically as a map, as well as a
table or a set of statistic properties etc.
Well I have no idea here; all I can do is point out that I learned GIS from GRASS and have no experience of any other GIS, and the concept that each raster and vector file is actually a real map was really helpful to me when learning.
Issue 2:
Actually, each raster and vector file is a file of geospatial data of some kind. To make a map (a visual and perhaps also an analytical entity), we combine or composite one or more of these files and display it in a GIS. The metaphor of combining multiple layers to produce a map is pretty widely understood too. I kind of like the conceptual clarity of differentiating the spatial data "layers" from the "map" that is produced in the GIS by compositing one or more layers.
The big issue comes if we want to switch the terminology as expressed in GRASS command modules: d.rast map=myraster vs. d.rast layer=myraster.
This begins to seem very reasonable if we are looking at the possibility of having something along the lines of d.rast layers=myraster1,myraster2,myraster3 map=mycompositedmap.ps
g.pnmcomp has similar syntax, but uses the generic "input=" and "output=" instead of "layers=" and "map="
Layers compositing into a map also makes much sense in the GUI canvas context. If you are combining a series of maps in a display context, what are you making in the end?
A few cents worth of thoughts.
Michael
