While you (plural) are cranking on the next release, it's probably not the best time to ask but...
- would it be possible to add the terracost functionality to r.cost (http://www.bowdoin.edu/~ltoma/research.html). My impression is that for a C programmer it would be fairly easy.
- file size limitations issues. I'm bumping up against a 2 gb limit in r.out.arc. We're using grass6.3, compiled with large file support and we can't export files that would be larger than 2 gb. My postdoc (who knows java but not C) and I looked at the source code for r.out.arc and couldn't see any obvious reason why there would be a size limit.
Jerry
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
- would it be possible to add the terracost functionality to r.cost (Laura Toma Research). My impression is that for a C programmer it would be fairly easy.
It would be good to use this as motivation to better document
the needed steps as already drafted here:
http://grass.gdf-hannover.de/wiki/Large_File_Support
The --enable-largefile configure option only enables LFS on code which
specifically chooses to use it. As r.out.arc only performs sequential
output, it's safe to enable LFS, so I've modified the Makefile to
enable it.
Thanks for this! I downloaded and recompiled (after a make clean) and it
seems to have worked fine. I also needed this for r.in.arc. I put the code
modifications you made into that make file and it also seems to have worked
fine. I was wondering whether you (plural, ie someone on the development
team) could drop those three lines of code into all the related routines. I
would think they are
r.out.arc
r.in.arc
r.out.ascii
r.in.ascii
others?
Thanks, Jerry
-----Original Message-----
From: Glynn Clements [mailto:glynn@gclements.plus.com]
Sent: Saturday, April 07, 2007 9:58 AM
To: Gerald Nelson
Cc: grass-dev@grass.itc.it
Subject: Re: [GRASS-dev] terracost and large files more generally
enable it.
r.out.arc
r.in.arc
r.out.ascii
r.in.ascii
Those all seem to be okay.
The r.out.* programs don't use file positioning at all, r.in.arc uses
fseek() with a zero offset, and r.in.ascii always uses reasonably
small offsets (either relative seeks of one or two rows of data or
absolute seeks near the beginning of the file).
I've committed the changes to CVS.
I would also add to that page that some exporting/inporting formats have their
own intrinsic limitations, see for instance:
http://www.gdal.org/formats_list.html
Francesco P. Lovergine
Raster drivers — GDAL documentation
Done.
