[GRASS-dev] Test suite North Carolina dataset
Hi devs, specially Vaclav
I discovered that the testsuite running in the North Carolina University server [0] is using the basic dataset. I discovered this because during Google Code-in a student provided some tests using the full NC grassdata and so they failed. I’m going to fix these next week.
However for some modules the full NC grassdata is required (for example imagery modules using the landsat data) so I would ask Vaclav to switch to the full NC grassdata.
What do you think?
[0] http://fatra.cnr.ncsu.edu/grassgistests/summary_report/nc/
