I just tried out d.thematic.area from develbranch_6 (updated from svn last night).
It compiled without error, but failed on running with the following message:
dyld: lazy symbol binding failed: Symbol not found: _G_gisinit
Referenced from: /Applications/Grass/GRASS-6.4.app/Contents/MacOS/bin/d.thematic.area
Expected in: /Applications/Grass/GRASS-6.4.app/Contents/MacOS/lib/libgrass_gis.dylib
dyld: Symbol not found: _G_gisinit
I’m on a Mac Intel with OS X 10.5.4
Michael
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
Arizona State University
I did not commit my last changes to develbranch_6, but to trunk...
Don't have the time right now to find out how to do this (actually wasn't sure I should without any prior testing from others).
I just installed your tarball, did a make clean, make, and make install.
I got the same error when I tried to run d.thematic.area
GRASS 6.4.svn (Spearfish60_test):~ > d.thematic.area
Trace/BPT trap
____________________
On Aug 12, 2008, at 10:14 AM, Moritz Lennert wrote:
On 12/08/08 18:58, Michael Barton wrote:
Moritz,
I'm on a Mac Intel with OS X 10.5.4
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
On Tue, Aug 12, 2008 at 6:58 PM, Michael Barton <michael.barton@asu.edu> wrote:
Moritz,
night).
Referenced from:
Expected in:
Referenced from:
Expected in:
the G_gisinit symbol thing was introduced the other day (backport, to
ensure that compatible GIS libraries are used).
Perhaps you have an old libgis hanging around somewhere?
"make distclean" is needed, too.
I updated from the svn last night and did a make distclean.
When was it backported?
Michael
On Aug 12, 2008, at 11:03 AM, Markus Neteler wrote:
Michael,
Moritz,
night).
Referenced from:
Expected in:
Referenced from:
Expected in:
Michael
Michael,
Moritz,
night).
Referenced from:
Expected in:
Referenced from:
Expected in:
I've updated from the svn develbranch_6,
installed the new d.thematic.area files by doing a tar -xvf thematic.tar
did a make distclean, and make.
None of d.thematic.area compiled.
I checked and none of the pieces were in the Make files any more, so I added them back in.
They still won't compile.
Michael,
Moritz,
night).
Referenced from:
Expected in:
Referenced from:
Expected in:
You need to compile lib/arraystats before you can compile display/d.thematic.area.
> night).
> Referenced from:
> Expected in:
> Referenced from:
> Expected in:
It's the other way around. It's trying to use an old gis.h with a new
libgis.
The new libgis doesn't have G_gisinit(), only G__gisinit() (with two
underscores, and an extra argument). The new gis.h has a G_gisinit()
macro:
Just comitted to develbranch_6. I had to sort through some of Glynn's architecture changes, but I think the backported stuff is all from me.
On Aug 13, 2008, at 2:33 AM, Moritz Lennert wrote:
Moritz,
