Moritz Lennert wrote:
>> > but at the minute my mind has gone blank as to the portable way to
>> > replace that. I general audit of calls to system() would have caught
>> > that if we're able to get round to doing it I suppose.
>> This might be priority to my testing via the GDF GRASS Tutorial, so I'll
>> try to do that first.
>> Should all system calls be replaced by G_system ? Should any system /
>> G_sytem calls be avoided ? Or should we check which system() calls use
>> functions which might not exist in Windows ?
> Avoid system() and G_system() equally. G_system() is almost identical
> to system(), except that it appears to work around a signal handling
> bug in some ancient system() implementations. Ditto for G_popen().
I've done a first "audit" of system() and G_system() calls. The result is
attached.
One line for the call, the next for the line(s) defining the command that
is being called.
I left out most calls to GRASS modules, except for those where I felt that
there might be pathname issue. At this stage, I also left out all the
display/ and the image rectification modules which have been replaced by
georectify.
I don't have enough knowledge to decide what to do about each of them, but
I'm willing to work on this provided someone can guide me.
general/g.mapset/main.c:135: ret = system ( buf ) ;
G_asprintf ( &buf, "%s %s/.gislock %s", lock_prog, mapset_new_path, gis_lock );
sprintf(path, "%s/.gislock", mapset_new_path);
G_spawn(lock_prog, lock_prog, path, gis_lock, NULL);
general/g.mapset/main.c:165: system( buf );
G_asprintf ( &buf, "/bin/sh -c \"%s/etc/clean_temp > /dev/null\"", G_gisbase() );
sprintf(path, "%s/etc/clean_temp", G_gisbase());
G_spawn(path, "clean_temp", NULL);
or:
G_spawn_ex(path, "clean_temp", SF_REDIRECT_FILE, 1, O_WRONLY, "/dev/null", NULL);
general/g.mapsets/main_cmd.c:91&126: system (command);
sprintf (command, "ls -C %s/%s 1>&2", G_gisdbase(), G_location());
G_ls(G_location_path(), stderr);
general/g.mapsets/set_path.c:65: if (system (command) == 0)
strcpy (command, "g.mapsets -p mapset=") & other strcat calls
sprintf(mapset_arg, "mapset=%s", mapset)
G_spawn("g.mapsets", "g.mapsets", "-p", mapset_arg, <other args>, NULL);
general/g.setproj/get_stp.c:198&315: G_system(buff);
sprintf(buff,"%s \"%s\" 1>&2", pager, G_convert_dirseps_to_host(Tmp_file1));
G_spawn(pager, pager, G_convert_dirseps_to_host(Tmp_file1), NULL);
or:
G_spawn_ex(pager, pager, G_convert_dirseps_to_host(Tmp_file1), SF_REDIRECT_DESCRIPTOR, 1, 2, NULL);
lib/g3d/g3dwindowio.c:226: if (access (path, 0) != 0) system (command);
strcpy (path = command, "mkdir ");
This is commented out, but in general use G_mkdir().
lib/gis/get_datum_name.c:83: G_system(buff);
sprintf(buff,"%s \"%s\" 1>&2",pager, G_convert_dirseps_to_host(Tmp_file));
lib/gis/get_ell_name.c:60: G_system(buff);
sprintf(buff,"%s \"%s\" 1>&2", pager, G_convert_dirseps_to_host(Tmp_file));
lib/gis/get_projname.c:74: G_system(buff);
All as for g.setproj above.
lib/gis/gisbase.c:34: system (command);
sprintf (command, "%s/etc/sroff", G_gisbase( ) );
G_spawn(command, "sroff", NULL);
lib/gis/gishelp.c:55: system(buffer) ;
sprintf(buffer, "%%GRASS_PAGER%% %s", file) ; /*ifdef __MINGW32__*/
sprintf(buffer, "$GRASS_PAGER %s", file) ;/*else*/
G_spawn(getenv("GRASS_PAGER"), getenv("GRASS_PAGER"), file, NULL);
lib/imagery/ls_groups.c:70&129: G_system(buf);
sprintf (buf, "$GRASS_PAGER %s", tempfile);
G_spawn(getenv("GRASS_PAGER"), getenv("GRASS_PAGER"), tempfile, NULL);
lib/init/mke_loc.c:179: system(buf);
sprintf (buf, "echo %s > \"%s/%s/%s/MYNAME\"", myname, gisdbase, location_name, mapset); & G_convert_dirseps_to_host(buf);
sprintf(path, "%s/%s/%s/MYNAME", gisdbase, location_name, mapset);
fp = fopen(path, "w");
fputs(myname, fp);
fclose(fp);
lib/proj/datum.c:300: G_system(buff);
As for other pager uses above.
lib/vask/V_clear.c:63: system("clear");
Commented out.
raster/r.average/main.c:94: if ((stat = system(command)))
sprintf (command, "%s -anC input=%s,%s fs=space > \"%s\"", STATS, basemap->answer, covermap->answer, tempfile1); & #define STATS "r.stats"
sprintf(input_arg, "input=%s,%s", basemap->answer, covermap->answer);
G_spawn_ex(STATS, STATS, "-anC", input_arg, "fs=space", SF_REDIRECT_FILE, 1, O_WRONLY|O_CREAT, tempfile, NULL);
raster/r.average/main.c:154: stat = system(command);
sprintf (command, "%s input=%s output=%s < \"%s\"", RECODE, basemap->answer, outputmap->answer, tempfile2); & #define RECODE "r.recode"
sprintf(input_arg, "input=%s", basemap->answer);
sprintf(output_arg, "output=%s", outputmap->answer);
G_spawn_ex(RECODE, RECODE, input_arg, output_arg, SF_REDIRECT_FILE, 0, O_RDONLY, tempfile2, NULL);
raster/r.coin/inter.c:32: G_system("clear");
raster/r.coin/inter.c:51: G_system("clear");
G_spawn("clear", "clear", NULL);
raster/r.coin/inter.c:87: G_system(command);
sprintf(command,"$GRASS_PAGER %s",dumpname);
raster/r.coin/inter.c:108: G_system(command);
sprintf(command,"cp %s %s/%s",dumpname,G_home(),outname);
We could really do with a G_copy(), but for now:
sprintf(path, "%s/%s", G_home(), outname);
G_spawn("cp", "cp", dumpname, path, NULL);
Except: the Unix version of G_home() is nonsense; the correct way to
determine the user's home directory is getenv("HOME").
raster/r.coin/inter.c:130: G_system(command);
sprintf(command,"lpr %s",dumpname);
G_spawn("lpr", "lpr", dumpname, NULL);
raster/r.kappa/stats.c:47: if (system(buf)) {
strcpy (buf, "r.stats -cin"); & many strcat() calles
G_spawn("r.stats", "r.stats", "-cin", <other arguments>, NULL);
lots in r.le/*, but all seem to be calls to GRASS modules, plus a series of G_system("clear") calls
Hopefully r.le won't be around much longer.
raster/r.out.mpeg/main.c:82: if (256 == G_system("ppmtompeg 2> /dev/null"))
G_spawn("ppmtompeg", "ppmtompeg", NULL);
or:
G_spawn_ex("ppmtompeg", "ppmtompeg", SF_REDIRECT_FILE, 2, O_WRONLY, "/dev/null", NULL);
raster/r.out.mpeg/main.c:84: else if (256 == G_system("mpeg_encode 2> /dev/null"))
G_spawn("mpeg_encode", "ppmtompeg", NULL);
or:
G_spawn_ex("mpeg_encode", "ppmtompeg", SF_REDIRECT_FILE, 2, O_WRONLY, "/dev/null", NULL);
raster/r.out.mpeg/main.c:319: if (0 != G_system(cmd))
sprintf(cmd, "%s %s", encoder, mpfilename);
G_spawn(encoder, encoder, mpfilename, NULL);
raster/r.out.mpeg/main.c:351: G_system(cmd);
sprintf(cmd, "cd %s; \\ls %s >> %s 2> /dev/null", path, wildarg, tfile);
Ick; leave this alone for now.
raster/r.out.mpeg/main.c:377: G_system(cmd);
sprintf(cmd, "\\rm %s", tfile);
remove(tfile);
raster/r.out.mpeg/write.c:351&356: G_system(cmd);
sprintf(cmd, "\\rm %s", file);
remove(file);
raster/r.report/stats.c:48: if(system(buf))
strcpy (buf, "r.stats -acr"); & more calls to strcat
See above.
raster/r.statistics/o_average.c:30: if (stat = system(command))
sprintf (command, "%s -an input='%s,%s' fs=space > %s", STATS, basemap, covermap, tempfile1); & #define STATS "r.stats"
sprintf(input_arg, "input=%s,%s", basemap, covermap);
G_spawn_ex(STATS, STATS, "-an", input_arg, "fs=space", SF_REDIRECT_FILE, 1, O_WRONLY|O_CREAT, tempfile1, NULL);
raster/r.statistics/o_average.c:70: stat = system(command);
sprintf (command, "%s input='%s' output='%s' < %s", RECLASS, basemap, outputmap, tempfile2); & #define RECLASS "r.reclass"
sprintf(input_arg, "input=%s", basemap);
sprintf(output_arg, "output=%s", outputmap);
G_spawn_ex(RECLASS, RECLASS, input_arg, output_arg, SF_REDIRECT_FILE, 0, O_RDONLY, tempfile2, NULL);
raster/r.statistics/o_sum.c:31: if (stat = system(command))
sprintf (command, "%s -cn input='%s,%s' fs=space > %s", STATS, basemap, covermap, tempfile1); & #define STATS "r.stats"
G_spawn_ex(STATS, STATS, "-cn", input_arg, "fs=space", SF_REDIRECT_FILE, 1, O_WRONLY|O_CREAT, tempfile1, NULL);
raster/r.statistics/o_sum.c:72: stat = system(command);
raster/r.support/front/run.c:19: if ((stat = G_system(buf)))
G_snprintf(buf, sizeof(buf), "%s/etc/support/%s '%s'", G_gisbase(), pgm, rast);
sprintf(path, "%s/etc/support/%s", G_gisbase(), pgm);
G_spawn(path, pgm, rast, NULL);
raster/r.support/front/run.c:37: if ((stat = G_system(buf)))
G_snprintf(buf, sizeof(buf), "%s", pgm);
G_spawn(pgm, pgm, NULL);
[Exactly why this doesn't just use G_system(pgm), I have no idea.]
raster/r.support/modhead/check_un.c:63: G_system(command);
G_snprintf(command, sizeof(command), "$GRASS_PAGER %s", tempfile);
raster/r.topmodel/misc.c:10: if(G_system(cmd)){
where command can be one of a series of GRASS modules
G_spawn(...)
raster/r.transect/main.c:135: exit (system(command));
sprintf (command, "r.profile %s input='%s' output='-' null='%s' profile=", coord_str, parms.map->answer, parms.null_str->answer); & more strcat() calls
sprintf(input_arg, "input=%s", parms.map->answer);
sprintf(null_arg, "null=%s", parms.null_str->answer);
G_spawn_ex(r.profile, r.profile, coord_str, input_arg, null_arg, <other args>, NULL);
raster/r.watershed/front/main.c:318: ret = system(command);
sprintf (command, "%s/etc/water/", G_gisbase()) ; & (strcat(command,"r.watershed.seg") || strcat(command,"r.watershed.ram") & more strcat() calls
sprintf(command, "%s/etc/water/%s", G_gisbase(), prog);
G_spawn(command, prog, NULL);
raster/r.watershed/shed/main.c:36: if (G_system (input.com_line_ram)) {
raster/r.watershed/shed/main.c:40: if (G_system (input.com_line_seg)) {
raster/r.watershed/shed/main.c:47: } else if (G_system (input.com_line_seg)) {
These might actually need to use G_system(); it depends upon where
input.com_line_* come from.
vector/v.transform/creat_trans.c:66: G_system("clear") ;
visualization/nviz/src/do_zoom.c:169: if (system(cmd) != 0) {
strcpy(cmd, "pnmcat -lr "); & more strcat() calls
visualization/nviz/src/do_zoom.c:184: if (system(cmd2) != 0) {
strcpy(cmd2, "pnmcat -tb "); & more strcat() calls
Ick. I need to either extend G_spawn[_ex] or add a G_vspawn
(G_spawnv?) function to allow for an array of arguments.
visualization/xganim/main.c:512: system(cmd);
sprintf(cmd, "cd %s; \\ls %s >> %s 2> /dev/null", path, wildarg, tfile);_______________________________________________
Same as r.out.mpeg; leave for now.
