[*] ... can someone test if 6.4's v.surf.rst works on XP/Vista/7?
we have been running it all semester on XP/Vista/7 without any complaints,
but I would have to specifically
check who actually ran it with GRASS installed under Program Files.
tested with the nightly-build WinGRASS-6.4.SVN-r42075-1-Setup.exe
(installed in c:\Program Files\ in WinVista32) and the example from the manual:
Spearfish example (we simulate randomly distributed elevation measures):
g.region rast=elevation.10m -p
# random elevation extraction
r.random elevation.10m vector_output=elevrand n=200
v.info -c elevrand
v.db.select elevrand
# interpolation based on all points
v.surf.rst elevrand zcol=value elev=elev_full
r.colors elev_full rast=elevation.10m
d.rast elev_full
d.vect elevrand
# interpolation based on subset of points (only those over 1300m/asl)
v.surf.rst elevrand zcol=value elev=elev_partial where="value > 1300"
r.colors elev_partial rast=elevation.10m
d.rast elev_partial
d.vect elevrand where="value > 1300"
v.surf.rst is working.
best regards
Helmut
___________________________________________________________
GRATIS: Movie-Flat mit über 300 Top-Videos. Für WEB.DE Nutzer
dauerhaft kostenlos! Jetzt freischalten unter http://movieflat.web.de
Helmut,
can you please put this in the bug tracker
http://trac.osgeo.org/grass/ticket/1038
although I just noticed that this happens when v.surf.rst is launched from wxGUI - have you tried that too?
Helena
v.info -c elevrand
d.rast elev_full
d.vect elevrand
d.rast elev_partial
best regards
Helmut
Von: Helena Mitasova
Betreff: Re: testing on XP/Vista/7 (v.surf.rst)
Helmut,
sure, see http://trac.osgeo.org/grass/ticket/1038#comment:3
best regards
Helmut
NEU: WEB.DE DSL für 19,99 EUR/mtl. und ohne Mindest-Laufzeit!
http://produkte.web.de/go/02/
