[GRASS-dev] Testing sample fire simulation data in GRASS 7
I wanted to test sample fire simulation data (http://grass.osgeo.org/download/sample-data/) in GRASS 7. I used the provided script and tried one command after each other (you cannot use the whole script because of r.spread X mon connection).
However, the r.ros command is working only partially for me:
GRASS 7.0.svn (fire_demolocation):~/… > r.ros -s model=fuel_model moisture_1h=1hour_moisture moisture_live=live_moisture velocity=wind_speed direction=wind_direction slope=slope aspect=aspect elevation=elevation output=my_ros
100%
ERROR: Invalid descriptor: 11
I’m in demomapset. All output maps are created (my_ros.base, my_ros.max, …) and I can run r.spread.
It seems that the error goes from lib/raster/close.c:
$ grep -Irn “Invalid descriptor” .
./lib/raster/close.c:74: G_fatal_error((“Invalid descriptor: %d”), fd);
./lib/raster/close.c:107: G_fatal_error(
Recently, we tried some other data on some other system and it worked without an error. Also in GRASS 6.4.3 it works without problems (except for the last commands but probably just the script is confusing or confused). My system is Ubuntu 13.10 64bit (gcc).
I don’t know what to test or look for.
Vaclav
On Thu, Jan 2, 2014 at 12:25 AM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
GRASS 7.0.svn (fire_demolocation):~/... > r.ros -s model=fuel_model
output=my_ros
100%
If you run it without -s, it works:
GRASS 7.0.svn (fire_demolocation):~/grassdata/fire_demolocation >
g.remove --q rast=my_ros.max,my_ros.base,my_ros.maxdir,my_ros.spotdist,my_spread,my_spread.x,my_spread.y,my_path
WARNING: ...
r.ros model=fuel_model moisture_1h=1hour_moisture
output=my_ros
100%
r.ros complete. Raster maps <my_ros.base>, <my_ros.max> and <my_ros.maxdir>
created.
So the issue in in the -s code.
wrote:
> Hi,
the
velocity=wind_speed
> output=my_ros
> 100%
g.remove --q
WARNING: ...
output=my_ros
100%
created.
Thanks for checking this. I overlooked the fact that I haven't used -s
before.
Even the <my_ros.spotdist> map is created and is the same in G7 and G6
(haven't tested, but I guess that only color table differs, see attached
screenshot).
I might look at r.ros -s related code but not sure when.
Vasek
(attachments)
I’ve created the ticket because I almost forgot about this.
https://trac.osgeo.org/grass/ticket/2209
output=my_ros
100%
WARNING: …
output=my_ros
100%
created.
Thanks for checking this. I overlooked the fact that I haven’t used -s before.
Even the <my_ros.spotdist> map is created and is the same in G7 and G6 (haven’t tested, but I guess that only color table differs, see attached screenshot).
Vasek
output=my_ros
100%
For the (ML) record: solved in 6.4, 6.5 and 7.svn.
