[GRASS-dev] Tests down to 58% (from 81%)
just to let you know in case you haven’t noticed, something between r61753 and 61763 broke a lot of temporal tests.
Vaclav
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-08-27-07-00/report_for_nc_spm_08_grass7_nc/testfiles.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-08-28-07-00/report_for_nc_spm_08_grass7_nc/testfiles.html
On Thu, Sep 4, 2014 at 4:43 PM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
just to let you know in case you haven't noticed, something between r61753
... "excellent", in a sense that your test suite starts to catch new issues!
We can narrow that down to r61760-r61763, before it was PNG driver stuff etc.
one wish:
Since you track "success" or "failed", could you please add an
additional column to retain the last rev number of "success" (maybe as
link to trac changeset)? Then one could easily navigate to the
subsequent changes.
thanks
2014-09-04 16:43 GMT+02:00 Vaclav Petras <wenzeslaus@gmail.com>:
Oh, no. I will try to investigate this. Thank you for checking this.
Soeren
Vaclav
subsequent changes.
The problem is that I do not track anything specific. I just generate the
HTML report and that's it. There might be some solution using key-value
files and searching through test report directory tree but the ultimate
solution is to store test result (values for report) in database and then
generate report from the database (so that current and previous values are
accessible in the same way and also better organized).
I have hopefully fixed the issues that caused the failure of tests in
r61806 and added some additional shell test files to the testsuite in
r61807.
Regarding the tests, can you please install python-ply (PLY[1] package
for temporal algebra lex and yacc parser) at the test server, so that
the temporal algebra tests will work, at least most of them?
Best regards
Soeren
[1] http://www.dabeaz.com/ply/
2014-09-04 21:27 GMT+02:00 Sören Gebbert <soerengebbert@googlemail.com>:
Soeren
Vaclav
On Fri, Sep 5, 2014 at 4:18 PM, Sören Gebbert <soerengebbert@googlemail.com>
r61807.
Great thanks, we can check tomorrow.
Let me wait with this for tomorrow, so we can see what was improved.
Best regards
Soeren
>> Hi,
r61753
> Soeren
>> Vaclav
r61807.
Tests are at 86% successful test files.
There is a problem with t.rast.to.rast3.
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-09-06-07-00/report_for_nc_spm_08_grass7_nc/temporal/t.rast.to.rast3/test_strds_to_rast3/index.html
Perhaps a missing region settings.
Installed, so let's see tomorrow.
Best regards
Soeren
>> Hi,
r61753
> Soeren
>> Vaclav
Perhaps the issue is that it is missing in
http://grass.osgeo.org/grass70/source/REQUIREMENTS.html
and in
http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu
and in
Great! Now we have 88% test files successful (was 86%), and 99% tests
successful (was 96%).
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-09-06-07-00/report_for_nc_spm_08_grass7_nc/testfiles.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-09-07-07-00/report_for_nc_spm_08_grass7_nc/testfiles.html
