[GRASS-dev] Tests down to 65% (from 86%)
something happened between r62745 (Saturday) and r62754 (Sunday) because tests are failing. Here are the changes in trunk:
http://trac.osgeo.org/grass/log/grass/trunk?action=stop_on_copy&mode=stop_on_copy&rev=62754&stop_rev=62746&limit=100&verbose=on
MarkusM, I’m not sure what was the actual change but it seems that G_tokenize() is the only related change. From the tests it seems that something in parser is failing.
I’ve also noticed that the documentation on server does not contain generated/standard flags (–), the flags are included when there is a short flag (-). I get the flags on my local machine with recent version. Was this changed somehow lately?
Vaclav
http://grass.osgeo.org/grass71/manuals/r.rgb.html
http://grass.osgeo.org/grass71/manuals/r.blend.html
2014-11-17 3:54 GMT+01:00 Vaclav Petras <wenzeslaus@gmail.com>:
I've also noticed that the documentation on server does not contain
generated/standard flags (--), the flags are included when there is a short
in r62756 [1] I added `--ui` flag, but it doesn't seems to be related
(needs more investigation).
Martin
[1] http://trac.osgeo.org/grass/changeset/62756
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.eu/mentors/landa
On Mon, Nov 17, 2014 at 3:54 AM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
MarkusM, I'm not sure what was the actual change but it seems that
G_tokenize() no longer removes leading spaces (it never removed
trailing spaces), but G_parser() relied on that. G_tokenize()
tokenizes a string, spaces can be removed with G_chop(), G_squeeze(),
or G_strip(). Fixed in r62763,4.
BTW, the test suite does not run with Python 2.6 because import
argparse fails, this module is new in Python 2.7.
Markus M
Vaclav
On Mon, Nov 17, 2014 at 11:32 AM, Markus Metz
but can be installed:
https://pypi.python.org/pypi/argparse
Best regards
Pietro
2014-11-17 11:32 GMT+01:00 Markus Metz <markus.metz.giswork@gmail.com>:
hm, the r.rgb still lacks flags in parameters section. Any idea? Martin
Martin Landa
About which platform do we talk about because now I’m starting to be concerned more about Python 3 which is appearing more and more as default.
I forgot to mention this in the other thread about gunittest backport, incompatibility with 2.6 is another argument against backport.
On Mon, Nov 17, 2014 at 5:32 AM, Markus Metz <markus.metz.giswork@gmail.com> wrote:
I know and I don’t know if 2.6 support is feasible. A lot of unittest functions was added in 2.7, so most of the tests would fail anyway. There is unittest2 package which can be installed separately and used instead of unittest in Python 2.6 but as I was reading about it it does not seem as smooth as I hoped for.
But perhaps installing unittest2 and argparse is worth trying. Few changes will be required in gunittest too, mostly imports I hope.
Vaclav
https://docs.python.org/2/library/unittest.html#assert-methods
https://docs.python.org/2/library/unittest.html#unittest.TestCase.assertRaisesRegexp
https://docs.python.org/2/library/unittest.html#unittest.TestCase.addTypeEqualityFunc
https://docs.python.org/2/library/unittest.html#unittest.TestCase.setUpClass
https://docs.python.org/2/library/unittest.html#unittest.registerResult
https://pypi.python.org/pypi/unittest2
I know and I don't know if 2.6 support is feasible. A lot of unittest
I will give it a try, argparse and unittest2 are available through the
package manager for my stock Python 2.6 version.
RHEL 6 and relatives, officially supported until end of 2020.
because now I'm starting to be
... for cutting (bleeding) edge distros, not yet for enterprise distros.
Markus M
Vaclav
On Mon, Nov 17, 2014 at 2:34 PM, Markus Metz <markus.metz.giswork@gmail.com>
changes
I will have to change imports to allow unittest2, hopefully today or
tomorrow. It should be simple to write but I will not test it.
Good to know, these are important.
On Mon, Nov 17, 2014 at 11:19 AM, Martin Landa <landa.martin@gmail.com> wrote:
I have changed lib/gis/parser_html.c in r62776, now it works for me. A
"Flags" section could not possibly be created if no flags were
defined, and the standard -- flags are never defined with
G_define_flag(). See also G_usage() in lib/gis/parser_help.c
Markus M
Martin
Martin Landa
Hi MarkusM,
2014-11-17 23:01 GMT+01:00 Markus Metz <markus.metz.giswork@gmail.com>:
I see, thanks for fix. I took liberty to backport this change
(including other changes) to relbr70 in r62784.
Martin
Martin Landa
Thanks, tests are back to 86%.
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-11-18-08-00/report_for_nc_spm_08_grass7_nc/testsuites.html
