[GRASS-dev] testsuite problems (t.connect)
Hi devs,
I added some tests [0] on t.connect testsuite to test the new "output"
parameter in t.list, t.rast.list, t.vect.list, t.raster3d.list [1].
These tests return me (also before my changes) this error [2] if I run
one after other.
I think this annoing problem (to use again GRASS I have to exit and
start GRASS) appear because in the setUpClass function a new mapset is
created and used but in tearDownClass function the old mapset isn't
set back and the new mapset is removed.
I tried to fix this problem but I'm not able to store the old mapset
somewhere and use it in the tearDownClass (self doesn't work because
@classmethod decorator). Do you have any idea to solve this?
[0] https://trac.osgeo.org/grass/changeset/67878
[1] https://trac.osgeo.org/grass/ticket/2319
[2] http://pastebin.com/xXSGcJw0
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
The classmethods don't have self but they have cls. These are the variables
you can set in the body of the class, e.g. mapsets_to_remove in the
test_distr_tgis_db_raster3d.py test [1]. You can assign the value in the
setUpClass method and use it in tearDownClass through the cls reference,
e.g. cls.mapsets_to_remove.append(mapset_name).
[1]
https://trac.osgeo.org/grass/browser/grass/trunk/temporal/t.connect/testsuite/test_distr_tgis_db_raster3d.py?rev=67878#L19
thanks a lot, I'm blind :-), I looked that code before write this email.
However fixed in r67888.
[1]
ciao
Luca
www.lucadelu.org
