[GRASS-dev] tgis.db
TGIS creates by default the DB in
$GISDBASE/$LOCATION_NAME/$MAPSET/tgis.db
probably better would be
$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/tgis.db
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Hi Martin,
why would it be better to put this single file in a separate directory?
Best regards
Soeren
2012/12/7 Martin Landa <landa.martin@gmail.com>:
Martin
2012/12/8 Sören Gebbert <soerengebbert@googlemail.com>:
because it's default 'database' for SQLite driver, see `db.connect`.
Martin
Hi Martin,
sorry i am confused. I made a svn update of grass trunk and typed
db.connect help.
The default path there is: "$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db".
I have had chosen the same path for the temporal GIS database. Has
this changed recently?
Is this really needed? If i change the default tgis.db path i need to
assure backward compatibility to avoid damage on existing temporal
GRASS locations.
Best regards
Soeren
2012/12/8 Martin Landa <landa.martin@gmail.com>:
Martin
db.connect help.
you have probably default connection settings already defined. If no
connection settings is defined and SQLite driver is available, then
`$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db` is used as the
default database [1]. Default DB for SQLite driver has been changed in
r52829 [2].
Martin
[1] http://trac.osgeo.org/grass/browser/grass/trunk/lib/db/dbmi_base/default_name.c#L130
[2] http://trac.osgeo.org/grass/changeset/52829/grass/trunk/lib/db/dbmi_base/default_name.c
r52829 [2].
looking at the comment (see the [2]), I am not sure if it's a good
idea to have more SQLite DBs in one directory. Probably MarkusM could
elaborate on that...
Martin
[1] http://trac.osgeo.org/grass/changeset/52829/grass/trunk/lib/db/dbmi_base/default_name.c
r52829 [2].
I see, sqlite is fsyncing its directory. So it may not be a good idea
to have two sqlite databases in the same directory
or in nested sub-directories.
Maybe its a better idea to use a separate directory like tgis or temporal?
$GISDBASE/$LOCATION_NAME/$MAPSET/tgis/tgis.db
$GISDBASE/$LOCATION_NAME/$MAPSET/temporal/tgis.db
Best regards
Soeren
Martin
On Sat, Dec 8, 2012 at 1:25 PM, Sören Gebbert
r52829 [2].
I have not tested this case, maybe it works. What does not work is if
an application is opening a file and another application is opening a
sqlite db in the same folder. The GRASS sqlite driver should print
reasonable error messages, so it should be easy to test
According to the sqlite documentation, that should be fail-safe.
Markus M
