while processing MODIS LST time series, I came across some questions
concerning best practice:
Say, I'm aggregating from daily temperature data a set of weekly
min/max/avg maps. So the best pracise is about
- using a reasonable name for the output strds
- using reasonable map names (alias "basename" in t.*)
They should be long-term understandable (with too cryptic names you
will have troubles even a few weeks later) but also parsable (think
"pattern" of g.list).
So, in my case I would call the output strds e.g. "lst_aggreg_modis_weekly".
I would use as "basename" something like "lst_${year}_avg_min_week",
"lst_${year}_avg_avg_week", "lst_${year}_avg_max_week".
(better ideas?)
But: do I put these three sets into a single strds or into three separate ones?
El sep 27, 2015 9:11 AM, “Markus Neteler” <neteler@osgeo.org> escribió:
Say, I’m aggregating from daily temperature data a set of weekly
using reasonable map names (alias “basename” in t.*)
“pattern” of g.list).
So, in my case I would call the output strds e.g. “lst_aggreg_modis_weekly”.
I would use as “basename” something like “lst_${year}avg_min_week",
"lst${year}avg_avg_week", "lst${year}_avg_max_week”.
(better ideas?)
Have you noticed the -s flag in t.rast.aggregate? It adds date to file names according to granularity of aggregation. I’ve discovered it recently and it is very useful for me.
If you use t.rast.aggregate and different methods, you get different strds. IMHO, this is best practice, since you can aggregate them to other granularities without having to select maps by method inside them. Does that make sense?
On Sun, Sep 27, 2015 at 2:35 PM, Veronica Andreo <veroandreo@gmail.com> wrote:
according to granularity of aggregation. I've discovered it recently and it
Oh, I didn't. Can you please post an example for the resulting map name(s)?
Then I add that to the manual.
(each run takes me half a day, so I would like to know what -s
produces before using it right away :-).
ones?
make sense?
Oh, I didn’t. Can you please post an example for the resulting map name(s)?
Sure! Please, find it attached as txt and modify as you like
