Anybody knows what is the v.buffer's `minordistance' option supposed to do?
The manual is not verbose about that, but as I understand it, together with `distance', it should allow to create a buffer with different extent along the minor and major axis, considering the specified `angle' of their rotation.
But none of the options works as that - the buffer size always equals the `distance', and the other 2 options make no difference if used or not an set to what.
BTW, it seems that -s, -c flags also don't have any effect on the output.
Did I get it wrong or maybe there's something broken?
6.4 SVN r60165, geos 3.4.2, Arch Linux 64bit.
Maciek
Maciej Sieczka
http://www.sieczka.org
On 03/06/14 19:59, Maciej Sieczka wrote:
of their rotation.
not an set to what.
In NC dataset:
v.buffer schools_wake out=testbuf distance=500 minordistance=250
gives me the attached buffers. Everything seems to work fine here...
Could you be more specific about what exactly is not working for you ?
Moritz
(attachments)
W dniu 04.06.2014 14:53, Moritz Lennert pisze:
to do?
of their rotation.
not an set to what.
In NC dataset:
Right, looks fine for points input. Not so for areas input though, e.g:
$ v.buffer testbuf out=testbuf2 distance=500 minordistance=250
v.buffer in the latter case does not honor minordistance and uses distance for both axes, while I would expect it to behave the way it does for points input. Am I expecting something which is not implemented maybe?
Maciek
Maciej Sieczka
to do?
of their rotation.
not an set to what.
output.
In NC dataset:
maybe?
For me this is more of a conceptual problem: how can you define a major and minor axis for buffers of polygons ?
Moritz
W dniu 04.06.2014 21:24, Moritz Lennert pisze:
to do?
`angle'
of their rotation.
not an set to what.
output.
In NC dataset:
maybe?
Maybe they cross at the centroid, rotation angle applies?
I was trying to make a minordistance=0.0111111111111111 distance=0.00694444444444447 vector area buffer in a latlon location. The northing/easting difference was supposed to copmpensate for the distance distortion, to some extent. But only then it came to me that it's better to reproject the input polygon to a metric location, create the regular fixed-distance buffer there, and reproject the buffer to the latlon location where I need it.
Maciek
Maciej Sieczka
Maciej Sieczka
