the list of blocker and critical tickets for 6.4.2 is reassuringly short:
#1158 Removing vector map in Windows fails with "Unable to delete vector map"
--> fixed, awaits confirmation
#1380 GRASS6.4.1 WX-Python GUI, menu does not work at all
--> probably fixed, awaits confirmation
#995 WxGUI startup screen fails if GISDBASE path contains non-latin characters
--> needs testing with current svn
#1110 v.rast.stats locks up on wingrass
--> I would suggest to replace v.rast.stats with v.rast.stats2 from
addons with has enjoyed more maintenance and testing in the last
months. Or port some fixes from v.rast.stats2 to v.rast.stats,
particularly r43910.
#1132 wxNviz and wxVdigit missing from 6.4svn
--> is this really critical for 6.4.2? nviz and v.digit are working AFAIK
#1184 "d.vect display=attr" imply grass open process but doesn't close them.
--> most probably fixed together with #1158 because it is the same
problem of the DBMI driver not shutting down
#1358 WinGRASS 6.4.1: SQLite driver errors: `Unable to open database'
#1388 r3.univar gives bad results for cell counts
--> fixed in June 2011 in all branches, awaits confirmation
2 are open: #995, #1358, one ticket (#1132) may need re-evaluation of
the priority, the remaining tickets are fixed, awaiting confirmation.
The only blocker is #1380 because #1158 is fixed.
Markus M
