[GRASS-dev] timestamp problems with PG driver
I am connected to a PostgreSQL database with a timestamp column.
While column type connection etc works there is a problem with the
leading "0".
The original timestamp
2010-03-26 05:31:25
is printed by v.db.select as
2010-3-26 5:31:25
Below an excerpt of debug output:
D3/3: row = 99 nrows = 100
D3/3: row 99, col 0, gpgtype 8, sqltype 6: val = '38.1958365'
D3/3: row 99, col 1, gpgtype 8, sqltype 6: val = '15.9744719'
D3/3: row 99, col 2, gpgtype 3, sqltype 3: val = '976451'
D3/3: row 99, col 9, gpgtype 16, sqltype 11: val = '2010-03-26
05:31:25' <<--- correctly fetched by PG driver
D3/3: Row fetched
D0/3: sqltype: 6
D0/3: Fetched valuestring: 38.1958365
D0/3: sqltype: 6
D0/3: Fetched valuestring: 15.9744719
D0/3: sqltype: 3
D0/3: Fetched valuestring: 976451
D0/3: sqltype: 6
D0/3: sqltype: 3
D0/3: sqltype: 3
D0/3: sqltype: 6
D0/3: sqltype: 3
D0/3: sqltype: 3
D0/3: sqltype: 11
D0/3: Fetched valuestring: 2010-3-26 5:31:25 <---
db_convert_column_value_to_string() failed
38.1958365|15.9744719|976451|||||||2010-3-26 5:31:25
As far as I understand, the formatting is getting lost in
lib/db/dbmi_base/columnfmt.c
which calls
db_get_column_value()
Is a kind of internal string conversion needed to maintain the leading "0"?
No clue...
thanks
On Mon, Jul 19, 2010 at 3:25 PM, Markus Neteler <neteler@osgeo.org> wrote:
leading "0".
2010-03-26 05:31:25
2010-3-26 5:31:25
D3/3: Row fetched
D0/3: sqltype: 6
D0/3: sqltype: 6
D0/3: sqltype: 3
D0/3: sqltype: 6
D0/3: sqltype: 3
D0/3: sqltype: 3
D0/3: sqltype: 6
D0/3: sqltype: 3
D0/3: sqltype: 3
D0/3: sqltype: 11
which calls
No clue...
As far as I understand C,
calls
lib/db/dbmi_base/valuefmt.c
db_convert_value_to_string()
that calls, in the datetime case:
lib/db/dbmi_base/datetime.c
db_convert_value_datetime_into_string()
I propose r42866 (trunk), backported to 6.5 and 6.4.
cheers!
anne
http://gis.fem-environment.eu/anne-ghisla/
leading "0".
2010-03-26 05:31:25
2010-3-26 5:31:25
D3/3: Row fetched
D0/3: sqltype: 6
D0/3: sqltype: 6
D0/3: sqltype: 3
D0/3: sqltype: 6
D0/3: sqltype: 3
D0/3: sqltype: 3
D0/3: sqltype: 6
D0/3: sqltype: 3
D0/3: sqltype: 3
D0/3: sqltype: 11
which calls
No clue...
calls
Now it lokos good:
v.db.select import_ed
58.157727|12.4292441|308824|||||||2008-03-26 14:01:11
46.0114738|11.0810102|74387|||||||2005-01-26 08:01:42
46.1332642|-0.3797519|295130|||||||2008-03-03 03:21:18.000288
thanks, Anne!
