On Sat, May 21, 2016 at 4:24 PM, <svn_grass@osgeo.org> wrote:
Author: amuriy
Date: 2016-05-21 13:24:32 -0700 (Sat, 21 May 2016)
New Revision: 68480Added:
grass-addons/grass7/vector/v.explode/
grass-addons/grass7/vector/v.explode/Makefile
grass-addons/grass7/vector/v.explode/v.explode.html
grass-addons/grass7/vector/v.explode/v.explode.py
Modified:
grass-addons/grass7/vector/v.delaunay3d/Makefile
Log:
<v.explode> script addedModified: grass-addons/grass7/vector/v.delaunay3d/Makefile
--- grass-addons/grass7/vector/v.delaunay3d/Makefile 2016-05-20
21:01:30 UTC (rev 68479)
+++ grass-addons/grass7/vector/v.delaunay3d/Makefile 2016-05-21
20:24:32 UTC (rev 68480)
@@ -1,4 +1,4 @@
-MODULE_TOPDIR = ../..
+MODULE_TOPDIR = /usr/lib/grass70PGM = v.delaunay3d
Hi Alexander,
just small tip which might be of interest to other contributors to Addons
as well.
There is no need to change the source code to achieve compilation of module
outside of GRASS source code. You can just run make like this:
make MODULE_TOPDIR=/usr/lib/grass70
and you avoid these things being committed (because you never need to add
them to the source code). Martin was so kind and already put that line
back. So now everything is fine.
Looking forward to more commits,
Vaclav
https://trac.osgeo.org/grass/changeset/68480
https://trac.osgeo.org/grass/changeset/68481
