[GRASS-dev] tmpfile() -> G_asprintf fails on Win/MinGW
attached is critical bugfix for G_asprintf(). tmpfile() fails on Windows/MinGW
if user des not have enough permissions on the drive (top dir) where he is
currently working.
Please apply to both HEAD and 6.2 release.
BTW, I dont think G_asprintf should be used in this cases:
  G_asprintf(&datumlongname, "unknown");
  G_asprintf(&ellps, "unnamed");
  G_asprintf( &pszDatumName, pszDatumNameConst );
Radim
(attachments)
asprintf.c.patch1 (889 Bytes)
On Fri, Oct 06, 2006 at 05:35:29PM +0200, Radim Blazek wrote:
Windows/MinGW
currently working.
Patch applied to both repositories (I have changed the C++ style comment, though).
Radim
unfortunately I found that it would not work when no mapset is open
(read only access) so I changed it to use Windows native functions to get temp
file. Another patch is attached.
Radim
> Hi,
> Windows/MinGW
> currently working.
> Radim
grass-dev mailing list
grass-dev@grass.itc.it
(attachments)
asprintf.c.patch2 (1.2 KB)
On Fri, Oct 06, 2006 at 08:38:07PM +0200, Radim Blazek wrote:
temp
Radim
Patch applied to 6.3-CVS and 6.2-rel-branch.
PS: Concerning your re-activation of ssh CVS write access, I
suspect that you may be missing "-1" in $HOME/.ssh2402
Mine is looking like this:
cat $HOME/.ssh2402
#!/bin/sh
ssh -1 -p 2402 $*
