GD Day Devs!
Configuring with --enable-64bit results in (working on Kubutnu 12.10, 64 bit
currently):
GRASS is now configured for: x86_64-unknown-linux-gnu
64bit support: yes
while leaving this option out results in
64bit support: no
And the question is to 64 or not to?
Thanks, Nikos
On Sun, Dec 30, 2012 at 6:21 PM, Nikos Alexandris
<nik@nikosalexandris.net>wrote:
GD Day Devs!
bit
currently):
64bit support: yes
I think your system is detected as x86_64-unknown-linux-gnu
and GRASS is configured to 64bit and not respectively
64bit support: no
Thanks, Nikos
grass-dev mailing list
grass-dev@lists.osgeo.org
Rashad
neteler
3
On Sun, Dec 30, 2012 at 1:51 PM, Nikos Alexandris
<nik@nikosalexandris.net> wrote:
GD Day Devs!
currently):
This is what Glynn said:
On Sat, Dec 19, 2009 at 6:55 AM, Glynn Clements
<glynn@gclements.plus.com> wrote:
Isaac Ullah wrote:
My configure options for
grass have 64-bit enabled, so shouldn't that set it up to look for all
64-bit architecture?
AFAICT, the --enable-64bit configure switch only affects AIX, HP-UX,
IRIX, and Solaris; it has no effect on Linux.
So, IMHO when you are on a 64bit Linux box, it will generate 64bit GRASS
anyway.
Nikos Alexandris:
> bit currently):
Markus Neteler:
anyway.
O-kay. Then I can ignore the message. Shouldn't the message, though, respect
what is really going on?
Thanks, Nikos
neteler
5
On Sun, Dec 30, 2012 at 4:01 PM, Nikos Alexandris
Would be ideal. Feel free to improve the script...
