[GRASS-dev] Tool-tip for removing map layer should state "remove" and not "delete"
I think the tool-tip for the button that removes a layer from the wxGUI
(which, if I understand correctly, does not correspond to g.remove) should be
described as "Remove selected map layer" or alike -- however, the verb
"delete" should not be used.
Currently the tool-tip states: "Delete selected map layer".
Thanks, Nikos
2013/1/8 Nikos Alexandris <nik@nikosalexandris.net>:
right, fixed in r54576. Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
