[GRASS-dev] Total area of a polygon changes by shifting using v.transform in grass6.5
Dear all,
Any body can help me to recover the problem like-
“Total area of a polygon changes by shifting using v.transform in grass6.5”
Thanks & Regards,
Swapan
"Total area of a polygon changes by shifting using v.transform in
grass6.5"
If I get the question right: intersect "before" and "after" with v.overlay,
then calculate the resulting area with v.report.
Actually I create a vector polygon using vector digitizing tool. My aim is to shift & rotate the created vector arround some elevated raster map using v.transform and create newvector.
Now I convert newvector polygon to raster suppose rast1.
Next generate report by passing two raster- elevated-raster, rast1.
After sending this maill I discover that vector area not changes but the converted raster area not same with vector polygon.
Thanks & Regards,
Swapan
grass6.5”
If I get the question right: intersect “before” and “after” with v.overlay,
