[GRASS-dev] trac #637: spaces in path names (wx + tcl)
re. stalled bug #637,
  https://trac.osgeo.org/grass/ticket/637#comment:11
I take it the wxGUI use of 'v.db.connect -g' still should explicitly
set the fs='|' and split() on that instead of space?
Also Tcl/Tk versions of same still need attention / testing /
backporting:
https://trac.osgeo.org/grass/log/grass/branches/develbranch_6/gui/tcltk/gis.m
https://trac.osgeo.org/grass/changeset/38295
https://trac.osgeo.org/grass/changeset/38296
https://trac.osgeo.org/grass/changeset/38426
https://trac.osgeo.org/grass/changeset/38427
and in general C code,
https://trac.osgeo.org/grass/changeset/38436
... maybe others
thanks,
Hamish
Yes.
backporting:
The dbmscap fix is in the wrong place. Any quoting should be done
within db_start_driver() (and the Unix version shouldn't be using the
shell; there's no need for it).
More generally, most of those quoting fixes are bogus. The solution is
to use G_spawn() rather than using the shell. Using the shell is a
bug; quoting is just a workaround.
