[GRASS-dev] Trac: Edit a single wiki section plugin
would this be useful (à la Mediwiki) to be installed?
http://trac-hacks.org/wiki/SectionEditPlugin
yes please
2010/1/25 Markus Neteler <neteler@osgeo.org>:
big yes! AFAIK this plugin requires version 0.11, unfortunately OSGeo
Trac instaces runs on 0.10.3.1 See [1].
Martin
[1] http://trac.osgeo.org/osgeo/ticket/365
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
On Tue, Feb 16, 2010 at 6:36 PM, Martin Landa <landa.martin@gmail.com> wrote:
Martin
OSGeo is in the process of acquiring two big servers which will be
hosted in a different place than the current one. Then services like
trac etc will be moved and updated.
See
http://wiki.osgeo.org/wiki/Infrastructure_Transition_Plan_2010
Martin:
> unfortunately OSGeo Trac instaces runs on 0.10.3.1 See [1].
Markus:
will be hosted in a different place than the current one.
Then services like trac etc will be moved and updated.
fyi,
in Debian/stable the version is: 0.11.1-2.1
and from backports.org: 0.11.6-1~bpo50+1
so the new servers should be able to handle it.
my advc. is to stick with the stable versions unless you just
can't live without something. (as better security fixes, support
etc using the official version)
Hamish
yes please
As of today, the plugin has been installed (possible after the migration
to the new server including upgrade to trac 0.11):
Example:
  Install the OSGeo4W directory structure [edit] <<---
There is a new [edit] button after each section title.
Happy hacking,
